Thread: DPKit: determing the centroid of a 'Part' ?
    Axes grinder- Dongle #99
    Seattle
    14,726
    Question DPKit: determing the centroid of a 'Part' ?
    How does one determine the 'centroid', if I'm using that correctly, of a DPKit-style 'part'?
    Praise to Buddha! #resist
    Jan 2005
    Colorado Springs
    1,784
    From a little testing, I'd guess it's the average of the point locations of the part. The attached scene rotates a "part" using DPKit Part Move, but the pivot point for the rotation is clearly NOT either the origin (modeler pivot point) or the center of the bounding box. BTW, as you probably know, you can specify the Pivot in the UI for Part Move.
    mTp
    Attached Files Attached Files
    Seattle
    14,726
    Monroe, indeed, you can specify it, but locating the proper numbers? That's what I'm trying to determine.
    Jan 2005
    Colorado Springs
    1,784
    Here's the Wikipedia article on the centroid:
    https://en.wikipedia.org/wiki/Centroid
    including the formulae to calculate the centroid of a polygon:
    https://en.wikipedia.org/wiki/Centro...oid_of_polygon
    which according to the introduction in the article:
    The definition extends to any object in n-dimensional space: its centroid is the mean position of all the points in all of the coordinate directions.
    I don't know what algorithm Denis actually uses to calculate it in Part Move, though.
    mTp
    Seattle
    14,726
    Yeah, that's the problem: what is the bbox of the "part".
    It might be there already. Or Denis might add it if he sees this post.
    (Which he has done before, merci beaucoup to him.)
    Jan 2005
    Colorado Springs
    1,784
    What problem are you trying to solve? If you need access to specific details or better control on a "part", move it to a different layer and treat it as a different object. Then, you have access to its Pivot Point directly in Layout via Modify => Move Pivot Point.
    mTp
