Results 1 to 12 of 12
Thread: PBR Metalness
    PBR Metalness
    Quick W.I.P. of a PBR Metalness nodal shader. Should work with all rendering (F9 and VPR). Allows you to export metalness textures from any of the 3D paint packages and render them in Lightwave. (3DCoat, Quixel, Substance) Will expand on the shader later and get abilities to mix in addition values. For now make sure that you are using CS sRGB for this to look right and that your normal maps are set to Linear. If your model has a vertex Normal Map make sure to assign it at the base surface level. Smoothing Angle also works.
    (best viewed on a sRGB monitor, not a 1080 rec709)
    http://artisaverb.info/PBT.html (if you want the gun model to try)
    Enjoy,
    -M
ID:	129854Click image for larger version.
    ack ack Markc's Avatar
    1,370
    Cool stuff, I will have to give this a try
    Barcelona
    1,691
    I'll give it a try too. Thanks!
    Salut!,
    Allabulle.
    Stuck in a very big cube Waves of light's Avatar
    South Yorkshire, England
    2,500
    Very nice. So straight export of the model, along with PBR surface nodes already setup. Sweet.
    Systen Spec: i7 4930k (OC @4.5ghz),ASUS p9x79 MB, 32GB Ballistix RAM, H60 cooling, Samsung SSD 120GB, WD 1TB
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,663
    Blog Entries
    I have Substance Painter
    Will give it a go in LW
    Intel Core i7-980, OC 4.7ghz water cooled.
    Gigabyte x58-UD3R with an Intell SSD 180GIG
    RamCorsair-DDR3-1600-32GIG
    Nvidia Titan Z, x 2 And 1 GTX-1080 by Gigabyte.
    4xEnterprise/WDVelociRaptorŪ300gig
    Registered User dreamtracing's Avatar
    Oct 2010
    Taiwan
    37
    Blog Entries
    Cool! Easy to use and thanks! ^~<
    How did this turn out for everyone?
    1,370
    Does anyone know if there is a way to save a Nodal setup so it can be loaded into a project empty, then just add the relevant image maps/uv targets?
    Obviously I can copy and paste, but could the preset shelf be used for this.
    Edit: Double Dohh!
    I can just save the surface (nodes arn't blank but it does the job)
    France
    498
    You should look at the "Compound Node".
    Newbie Member
    Oct 2017
    Houston, TX
    Thanks MSherak, I'm going to give this a try later!
    Super Duper Member kopperdrake's Avatar
    Mar 2004
    Derbyshire, UK
    3,134
    Thanks -M- - I'll give it a bash next time I'm in 3D Coat
    - web: http://www.albino-igil.co.uk - 2D/3D Design Studio -
    - PC Spec: Intel i9-7940X @3.1GHz | 64Gb | 2 x GeForce GTX 1080 Ti 11Gb | Windows 10 Pro -
    1,844
    Does the compound node get instanced across a scene?
