Thread: What "Esclude From VStack" is good for
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,155
    I have been working on a project that has a lot of transparent glowing tubes overlapping to produce an abstract effect. In VPR the lines looked good but in renders I was getting bright hot spots where my objects intersected each other. This was puzzling because I thought VPR and F9/F10 renders should basically be the same. I was considering just using screen shots of the VPR window as the art but after playing around with the surface settings I found that turning on "Exclude from VStack" fixed the problem.
    I never knew what this setting was for before now. Here is what the manual has to say about it: "A feature called “Exclude From VStack” for surfaces has been implemented. This way when you use polygons to replicate things like fire or space ship engine flames, these polygons are excluded from being included with the volume stack."
    So this is a good option to turn on if you don't want to see the edges where transparent objects intersect each other.
    Dec 2008
    New York City
    1,155
    Oops. I see I misspelled Exclude in the thread title. And I cant edit the title. How embarrassing.
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,692
    So if you mapped something on to say a cone ( like spaceship engine flames ) the end of the cone or all the ploys of the cone wouldn't render?
    Like adding transparency?
    I've always wondered exactly what this feature does.
    Dec 2004
    San Juan Island
    4,686
    Exclude from VStack removes the refraction and internal reflection computations. It is usually employed in a nested or series of dielectrics: wine in a glass, etc. Outside of that, it has no effect.
    Dec 2008
    New York City
    1,155
    That is good to know spherical. It seems like Exclude from VStack should be turned on when making overlapping transparent and glowing effects. Attached are some tests. I am getting interesting things happening in areas where the rings are overlapping.
    Dec 2004
    San Juan Island
    4,686
    Nice stuff! I'll have to fiddle with that some.
