Thread: Noob playground: Nodal Instance Rotation/.... never mind, 'gotcha' warning/Noob alert
    Axes grinder- Dongle #99
    Seattle
    14,733
    Smile Noob playground: Nodal Instance Rotation/.... never mind, 'gotcha' warning/Noob alert
    Just trying to get a hand on controlling instance rotation via nodes. Set up simplest possible network, but it no workee. (see JPG, scene)
    A rotating null feeds its rotation directly into........ OH WAIT.
    For the education of others: if you are going to nodally control Instance rotation, be sure to set the ROTATION: MODE to UNIFORM, otherwise nothing happens.
    Carry on.
    (That is: nodes don't AUTOMATICALLY override all Rotation parameters just by existing. That was my mistake, I assumed that USE NODES would automatically override most values. Personally, I think it should, but tell it to the devs.)
    Praise to Buddha! #resist
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,121
    Yes this was discussed in this thread: http://forums.newtek.com/showthread....n-in-LW-2015-2
    I put in a bug report on it and I was told that that it would be sent on to the team. That was in June and it is not fixed in 2015.3. I don't know if they will do anything about it if more people don't complain. Its totally confusing when you first run in to this.
    Seattle
    14,733
    Quote Originally Posted by lertola2 View Post
    Thanks for that. It made me feel really stupid. -er.
    not the best prose, but:
    Instancer Nodal network FAILS to override rotation controls
    Instances-Nodes.zip
    If a user chooses the wrong mode when using Nodes in the Instancer, the network fails to operate. This seems incorrect to me, in that generally it seems that nodal networks override settings in the panels.
    In the attached scene, the instances' rotation is controlled by a null, but setting the ROTATION/MODE to anything but Uniform negates any effect the network has.
    IMO this is a design flaw, and if the destination node has an input attached, the MODE selector should be ghosted. Additionally, greater mention in the dox as to this behaviour would be appreciated.
    TO REPLICATE: open the INSTANCE PARENT Object Properties, open the Instancer, try different MODES in the Rotation tab.
