Results 1 to 13 of 13
Thread: Best way to make Cube maps / Skyboxes?
    Mar 2010
    SATown
    666
    What's the best way to natively build a cubemap for a skybox in LightWave?
    (I mean without plugins)
    Thank you,
    -Chilton
    Dec 2004
    San Juan Island
    4,686
    You mean Cube Projection VRs and similar? If so, I set a camera where I want the node to be, set 90° FOV, set six frames - each keyframed to rotate the camera to render a side of the box, F10 with Image Sequence.
    Mar 2010
    SATown
    666
    Marcus that is perfect. I will use that.
    Spherical, that looks like exactly how Marcus's scene is set up.
    I can use this.
    Thanks!
    -Chilton
    Dec 2004
    San Juan Island
    4,686
    Yes, except if you want to render a VR; in which case the camera location would not be at Origin, but at eye level (or arbitrary elevation) and where you want to be to look around. Been doing them this way since 2003 or so.
    Near Beaverton, OR
    1,772
    Ya might want to check out UberCam. I does Skyboxes among other things.
    http://www.liberty3d.com/tag/ubercam/
    They just announced a new update and are having a special as well.
    Dec 2004
    San Juan Island
    4,686
    Ummmm... Chilton writes UberCam.
    Mar 2010
    SATown
    666
    Yeah I can see why that would be confusing--why would I care how to build a skybox if I can already build a skybox?
    The truth is, I think UberCam Skybox is slightly off, and I'd like to make it better, so I wanted to see another approach.
    I personally don't use Skyboxes anymore, as the lat-long cylinder mapping in Unity + UberCam Immersive is a really simple and bulletproof solution.
    But knowing UberCam's skybox isn't perfect really irks me. So I'll have that fixed shortly.
    -Chilton
    Dec 2004
    San Juan Island
    4,686
    That's what I figured was going on. And, Don't call me "Shortly".
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,375
    fix
    8,067
    Why do you want to use this silly cube mapping? It's not utilizing memory & space efficiently..
    It will create regions of varying details.
    Mar 2010
    SATown
    666
    I am climbing this mountain because it's there.
    Admittedly, this is not always the best idea.
    -Chilton
    Dec 2004
    San Juan Island
    4,686
    I know you're going to give me some mathematical proof that I won't immediately grok but where would there be "regions of varying details" when seen from the 0,0,0 of the cube? Yes, the corners are farther away but no one cares. Even knowing where the corners are, I cannot locate them in a cube projection. I was dubious, at first, when considering cube mapping over spherical mapping but, after trying the former and not seeing any artifacts, adopted that mode. Spherical mapping has a far more serious "regions of varying details" with expansion at the equator and compression at the poles or no expansion at the equator and all of everything else progressively compressed the farther away from it. That's a lot of lost data. Gotta compromise somewhere when morphing 3D to 2D and then back again.
