One of my client produces local soccer matches... His system consists of 4 Cam, SDI Switcher and 3Play 440.
Now he wanted to add a "cheap" CG... for clocks score etc...
There are several decent "Airsend" based CG out there... typically cheaper then their SDI counterpart...
So we found a workaround using the 3Play as the CG "Keyer"
so the setup is like this:
Cam 1 - 4 [DA] out 1 > Switcher inputs
[DA] out 2 > 3Play input 1-3
We need to sacrifice one input, so you can only replay from cam 1-3
Switcher output > Input 4 of 3Play
3Play output A > Switcher input 5 (for replay/slo-mo)
3Play output B > On air (always in LIVE mode looking at Input 4 [from switcher])
this way you can insert the CG via 3Play... some sacrifice, but doable... this was acceptable to my client...
Just thought I share it here...
