Thread: Inertia has falloff with Weight Map - bug?
    London
    2,336
    I'm having a problem with the Inertia displacement plugin.
    The attached is an object with a simple move on it, with Inertia applied. There are a few planes within the object all with their own unique value within the same Weight Map. With Inertia set to the Weight Map, I would have expected the planes to keep their shape during the displacement but with delayed movement. Instead, everything seems to have a falloff from the origin.
    Has it always been like this or is it a bug?
ID:	127769   Click image for larger version.
    hi, nope, that is a correct movement, not a bug...
    London
    2,336
    Thanks erikals, I went nodal in the end
