Results 1 to 15 of 17
Thread: making splash shapes
    Plays with fire sadkkf's Avatar
    Outside looking in
    1,224
    Hi--
    I'm trying to make splash shapes like the ones in the attached image, but am having a hard time with it. I've been playing with fluids in Blender and cool as it is, they're hard to control. Hypervoxels in LW seem okay, but really don't provide enough randomness and realism for me either.
    Any ideas? I only need solid texturing so no water or anything fancy.
    Thanks!
    So much water, so few sharks.
    "...all men are created equal." -- US Declaration of Independence
    San Antonio, texas
    76
    Modo has a splash kit: The Splash kit for MODO consists of meshes, materials, environments and assemblies – along with informative tutorials about their use for creating images with realistic splashes, drops and puddles. You have total control over shapes, color, lighting and camera position to create one-of-a-kind (and royalty-free) liquid imagery.
    cheers.
    Outside looking in
    1,224
    Quote Originally Posted by Fsoto View Post
    cheers.
    That's a really neat idea, but looks a little pricey. I don't own Modo and think a trial version would expire before I could get the hang of this.
    16,270
    perhaps try metaballs in modeler, blends like voxels, but you can freeze and further tweak model and refine the geometry as you want.
    I think blender could do this job pretty good. I created this with blender + lightwave + octane some months ago for fun. It was easy but of course takes some time to achive good quality.
    http://svenart.de/3d/paint2014.jpg
    16,270
    Quote Originally Posted by Svenart View Post
    Makes me want to start paint with real life colors again
    San Antonio, texas
    76
    Good job Svenart!
    Outside looking in
    1,224
    Yes, very nice work! I am going to need more specific shapes, though. I can't believe it's this hard to produce.
    Senior Constrictor Netvudu's Avatar
    Sep 2003
    Barcelona, Spain
    928
    although this video is Modo, I think most techniques used there are perfectly doable in Lightwave
    https://youtu.be/C4M81zhFaO4
    3d animation? Hah! Did you take a look through your window?there´s plenty of it...and pre-rendered!!
    Sep 2003
    Barcelona
    1,700
    Pretty interesting link, thanks Netvudu!
    Salut!,
    Allabulle.
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,175
    Quote Originally Posted by Netvudu View Post
    Exactly what I was about to suggest, just model it by hand. Instead of sitting days trying to get dynamics/ fluids to produce what you are after. Spend one day model it instead. It so easy to loose time when you are dealing with dynamics, its so hard to control in an efficient way.
    Unfortunately while we can do that kind of modeling in LW we can't have a screen up at the same time viewing the camera angle against the concept art.
    16,270
    3dpowers metamesh would probably be a good tool to invest in, would be easy I reckon to blend som base geotype to get what is needed, otherwise, start with some points and metaballs to get mainshape, then use modify tools to tweak it.
    Michael
    South Yorkshire, England
    2,500
    Using the methods in the Blender video, coupled with Magic Bevel and 3dpowers Metamesh plugin... I think that could be doable.
    Jan 2005
    Colorado Springs
    1,844
    It may not meet your needs regarding realism, but you might be able to use ClothFX on a mesh sheet and an Animation Path wind dynamic object. The sample scene was built using a "red water sheet" with the thin cotton template and maneuvered with the wind animation path. The sheet was then cloned, onto which a procedural clip map was added to makes holes / splashes, a procedural displacement to offset it from the original, and the ClothFX parameters were modified to have it lag the original.
    Note that you need to go into the Object=>Properties=>FX tab and press "Calculate" to calculate the wind effects on the cloth to see the effect.
    Might be worth playing with to see if you can get what you want. The handles on the wind animation path can be used to change the path, and probably a weight map could make the splashes leave the path a bit more.
    mTp
    Attached Files Attached Files
