Results 1 to 2 of 2
Thread: Lightwave Liveset Generator. Need help, please
    Mar 2012
    Ukraine
    2
    Hello. I'm using Lightwave 9.3 x32 and Liveset Generator plugin for exporting to Tricaster. Problem is that normal render has smooth panels in left and right, but when exporting with LivesetGen orange color in panels is floating...
    Camera preferences - Focal length 28, Resolution - DV PAL Widescreen, Antialiasing - 9 (tried 21, same problem), Reconstruction Filter - Gaussian sharp
    Help please
    Jan 2013
    Florida
    353
    Maybe try rendering out just the panels as an image by themselves and then use that image as a projection map on the panels in your final render.
    Gear Used:
    TriCaster: 40
    Cams: Panasonic AVCHD
    http://studio.ourtrainingacademy.com
    Newtek User since VT2.0
