Thread: Using character in another scene
    Hi!
    Here I go again with another silly question, say I have a nice character I created in modeler and then I hooked up some bones to it in Layout (so I have no skelegons) and all works fine in that scene, but I want to use the same character in another secne.
    What is the correct way to get this character into another scene complete with bones ? should I export the bones using the Setup/Edit/Export RIG ? or is there some other way to do this that I missed.
    I would have the same problems if I import for example an FBX file, I only have the bones in Layout, no rig information in the .lwo file when I save that.
    File/load/load items from scene
    Ah, it was that simple, easy to overlook the most obvious things.
