Results 1 to 9 of 9
Thread: Iterate through points
    pointCount on a box results in 8 but the iteration loops fails after index of 5. What gives.
    Code:
    main
        mesh = Mesh(0);
        info (mesh.pointCount(1));
        pc = mesh.pointCount();
        for(i=1; i <= pc; i++)
        	pnt = mesh.points[i];
        	nPos = mesh.position(pnt);
            info (nPos);
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    This same code works in Layout but not Modeler...what the!
    www.ernestpchan.com
    Oct 2003
    Near Edinburgh
    246
    Just ran a test in modeler 9.6 with and without debug, get all 8 points on a basic box.
    Quote Originally Posted by iain_r View Post
    Ok, something must have broken in 11.6.3 then.
    Thx iain_r for checking.
    www.ernestpchan.com
    8,280
    What does 1 mean in 2nd row "info (mesh.pointCount(1));"
    What is difference between "info (mesh.pointCount(1));" and "info (mesh.pointCount());" ?
    (I would use info(pc) - that's loop counter after all)
    Check to which it goes when you remove info()
    f.e. add info after whole loop, just read i variable.
    In C/C++ LWSDK pointCount() takes argument whether returned should be all points, or selected points, or deleted points.
    Oct 2003
    Near Edinburgh
    246
    When I run this in 11.6.3 with debug it finds all the points, however when not in debug I get the following error message "Line 14, illegal index value: point[5]"
    Iain
    Oct 2003
    Near Edinburgh
    246
    Broken from 11.5, tried that and 11.6
    Iain
    Oct 2003
    Near Edinburgh
    246
    Points in object
    You can try this piece of code for modeler
    Regards
    Iain
    Code:
    @version 2.8
    @warnings
    @name NumberPoints
    @script modeler
    main
        selmode(USER);
        pc = pointcount();
        info(pc);
        editbegin();
        	nPos = pointinfo(points[i]);
            info (nPos);
        editend();
    Thanks! Will do.
    www.ernestpchan.com
