Results 1 to 8 of 8
Thread: Flipping tiles!
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,689
    Flipping tiles!
    I am trying to animate a line ( strip ) of squares, that are all unwelded, as polygons flipping over 180 degrees but need each polygon to be offset as the strip turns.
    The strip follows a null but at the moment all the ploys turn at the same time.
    How can I offset them doing it nodally?
    Registered User Slartibartfast's Avatar
    Jun 2012
    Sweden
    420
    something like this. It uses DPKit partmove in the nodal displacement editor.
    May 2006
    Bristol, England
    1,689
    Thanks Slartibartfast
    So is it the Gradient that twists the polygons, and will they turn over 180 degrees when following a null?
    Jun 2012
    Sweden
    420
    Yes, The distance between the NULL and the "part" (tile) is fed into the gradient which outputs values from zero (through alpha channel) to PI radians (=180 degrees). PI = 3,1415-ish = 314,15% when expressing it as a percentage like in alpha...
    after some modification:
    If you're having trouble and want a specific effect you can upload your scene and I'll try to help you.
    Registered User speismonqui's Avatar
    Jan 2008
    Panama
    525
    @XswampyX did a video a while back:
    https://www.youtube.com/watch?v=qN0zvzNeu5I
    you can find the threat in the comments section, also there's the file XswampyX uploaded.
    TNX XswampyX, you're great!
    Dell XPS 8930 8-Core i9 9900K - 64GB DDR4 - GeForce GTX 1050 Ti - Windows 10
    MSI Prestige PS63 4-Core i7 8565U - 16GB DDR4 - GeForce GTX 1050 Ti Max-Q - Windows 10
    May 2006
    Bristol, England
    1,689
    Thank you everyone.
    I'll try all suggested to see if I can get the effect I'm after.
    Great support there -- LW users
