Results 1 to 9 of 9
Thread: Creating an Ice Material
    Feb 2010
    Kansas City
    1,141
    I found one tutorial for LW, but finally gave up and used Modo to create something. However, I love LW's interface and would rather use it and its renderer for this. Any ideas on ice material creation?
    "Once one can articulate an important idea into a concise statement, then one can use the statement and not have to have the fear of changing behavior." - Ed Catmull on Pixar creativity
    Dec 2004
    San Juan Island
    4,686
    Please describe the type of ice. It has many variations.
    Feb 2010
    Kansas City
    1,141
    Bluish nearly clear on the inside, clear on the edges.
    This is a very good tutorial, but I wasn't able to reproduce what I actually envision. Any ideas will help.
    http://www.imagecommunications.de/tu...thickness.html
    Registered User Slartibartfast's Avatar
    Jun 2012
    Sweden
    420
    Ice, glass, water and pretty much everything with reflectivity and/or transparency will need a good surrounding world to show off it's properties. So before you start tweaking the ice surface, make sure you have a textured background and some objects in the scene. Regarding the ice itself, you can use fracture to slice it up a bit to give it some internal surfaces to reflect and refract light.
    Just use the dielectric shader and you are done!
    Feb 2010
    Kansas City
    1,141
    Wow! Thanks for all the input. One other reason I liked doing this in LW is because of Fracture. It's so easy to use!!
    May 2014
    Greece
    141
    Unless you want big scale ice, where SSS is visible, use dielectric. You could also add bubbles inside the ice cubes, good luck!
    Dec 2004
    San Juan Island
    4,686
    Yes, Dielectric with a procedural. Boolean small to large bubbles out of the ice mesh interior or, in Layout, place modeled spheres within the ice mesh volume or add nulls inside the shape and attach various diameter HVs to them. Then use this technique: http://forums.newtek.com/showthread....=1#post1416384 to add foam micro-bubbles inside amongst the HV/modeled bubbles.
