Results 1 to 15 of 15
Thread: Zbrush texture/normal/displacement maps into Lightwave
    Sep 2010
    UK
    20
    Does anyone know of a detailed, carefully written pipeline for exporting ZBrush textures into Lightwave. There seems to be a non-intuitive sequence that needs to be followed exactly with V-flipping and/or G-flipping etc. I've tried various combinations but usually end up with the Normal maps not fitting exactly. I've tried making all the maps in Zbrush, Alpha-flipping and then GoZ-ing everything. Honestly, I'm rather at my wits end here and would be grateful for a sequence to follow. Thanks.
    Use GO-Z works fine for me
    North Carolina
    11,399
    For normal map rendering in LW you simply need to flip the green channel either inside Zbrush normal map generator, or photoshop, or you can click the flip Y axis (green channel) checkbox inside the normal map node in LW nodal. Yes, you must flip all maps inside zbrush or photoshop on the vertical axis. GoZ would do that for you automatically. GoZ also turns the flip Y axis checkbox on for you inside the nm node.
    North Carolina
    11,399
    Here's an old video that goes through the 16bit TIff displacment map process for rendering in LW. 2:34
    https://www.youtube.com/watch?v=XhX54lliHWE
    Sep 2010
    UK
    20
    Thanks for the reply Jason. I'm still stuck though. The screengrabs show my settings in ZB prior to hitting GoZ. I tried checking and unchecking the V flip on both the map generator and the Alpha menu. I've also tried generating the maps manually in multi-map exporter with a similar result. The N map and D maps appear on the VPR as slightly out of register. Oddly, Octane uses just the base mesh with an NM! You might wonder why I'm trying to get my model into LW at all - I need FibreFX, to avoid making polygonal fibers in ZB. Thanks again, David
Name:	GoZ to LW.jpg
    North Carolina
    11,399
    hi, I didn't know you were using octane. I'm not familiar with that but I'm pretty sure you need octane nodes to get the displacement working. I would take a look at your documentation.
    Sep 2010
    UK
    20
    Hi Jason, I need to go through Lightwave's Octane plugin, so I'm forced to find a way to texture my model in Lightwave first. Do the settings that I've posted look correct to you?
    I don't have experience with ZBrush, but anyway you are going to need to use the Octane nodes to render your displacement or normal map in Octane for LightWave. The work flow is not the same at all.
    For example for a displacement you need this kind of nodes setup:
    And for normal mapping this one:
    -Juanjo
    Juanjo Gonzalez
    Computer Graphics Software Developer
    Sep 2010
    UK
    20
    Thank you for this Juanjo, I'll try this out later and get back to you - I might need to redo the maps. David
    North Carolina
    11,399
    well make sure you know what kind of normal map you need or you may have to experiment (which color channels need flipping). Also make sure what kind of formats and bit size octane can use for displacements (16 or 32 bit, .tiff or exr.
    Otherwise I'd say you're are going about it ok.
    Sep 2010
    UK
    20
    Bingo! All I needed was a Normal map but curiously both it and the texture map required the Zbrush V-flip to be unchecked. Now to the job I've been dreading, translating the skin texture. Thanks again.
    TD/Animator lino.grandi's Avatar
    Jun 2003
    Rome
    1,701
    Lino Grandi
    3D Development, LightWave 3D Group/NewTek, Inc.
    https://www.lightwave3d.com/
    LightWave 3D Group YouTube channel:
    http://www.youtube.com/user/Official...?feature=watch
    My YouTube Channel:
    http://www.youtube.com/user/linograndi?feature=mhee
    Sep 2010
    UK
    20
    Thanks Lino, This is really helpful. I've not used GUV tiles before - I presume that I save them out in the usual way in Zbrush. If you are reading this Juanjo, can you say if GUV tiles are supported in Octane and whether or not the V-flip in Zbrush is still needed?
    I'm working on a transcription of the Octane Tony Sculptor skin-shader and will post the NOD file in due course.
    North Carolina
    11,399
    Fair warning, you aren't going to get nice results with Tangent Space normal maps using tiled UVs. Too many seams. GUV tiles work ok with displacements however.
    Sep 2010
    UK
    20
    Thanks Jason, This wouldn't have occurred to me - you've probably saved me a few days and who knows how many brow wrinkles!
