Results 1 to 15 of 18
Thread: Bullet and mdd
    Bullet and mdd
    Hi there!
    Is there a trick to get a bullet simulation to collide with MDD animated files ?
    I can't get It to work
    Thank you!
    Registered User imshadi's Avatar
    Dec 2003
    Costa Rica
    99
    Quote Originally Posted by marchermitte View Post
    Hi there!
    Thank you!
    1. Add your MDD collision object to Bullet as a DEFORMING object.
    2. Set it's shape retention to 100%
    3. Set Shape Lock to <Translation and Rotation>
    It worked for me.
    Oliver Zúņiga
    VFX Supervisor
    MarteStudio
    www.martestudio.com
    done that. With a very basic test scene (a cube animated with MDD, a pool filled with dynamic spheres) I get inconsistent results, like the test mesh (the mdd driven one) does deform like chewing gum, sticks to the hard body spheres. It doesn't matter if I use the filter mesh or not, linear and angular stiffness to 100, lock trans and rot + shape retention to 100 (even tried with keep volume) Noting works correctly. I don't get It, why can't we just have what the traditional LW hard body and cloth fx used to have, an fx_collision function that scan the mesh and use It's vertex position to collide with other dynamic meshes? What are those inefficient workaround?
    I can post the scene and videos.
    Medical Animator mummyman's Avatar
    Aug 2009
    Connecticut
    1,069
    Is the displacement MDD file added through nodes? That's how mine was set up in an older scene I did that used MDD files and a bullet sphere bouncing on them. Just a thought. Mine worked either way, though nodes or the MDD reader.
    Nope. Trying that right now
    Same thing. look at the video and at my settings... It does kind of work, because , as you can see, the sphere are pushed by the cube (not when the cube moves too fast) BUT the cube keep deforming with the sphere interpenetrating It.
    San Jose, CA
    6,717
    Is the cube only supposed to be deforming due to the MDD? If so, I'm not sure setting it as a "deforming" body is the right setting in Bullet, as that seems to tell Bullet it should be deforming based on collisions as well, which doesn't seem to be what you're seeking.
    I believe there's a setting that tells Bullet the object can undergo external deformation-type animation (effectively tells Bullet to continually update it's shape), but where Bullet still treats it as a "rigid body" for its own purposes. Maybe try "kinematic" for the cube? Just a guess, I'd need to experiment a bit, and can't really do so at the moment.
    John W.
    might want to try a 6 sided Box instead, or a lowres proxy object.
    Done that in the beginning, same problem , that's why I subdivided the cube (and collision detection with the sphere seems to be better now)
    Jwiede, The cube isn't supposed to be deformed. Using deforming body on a mdd animated mesh, with lock shape and shape retention at 100% is normally the way to get the mdd file to interact with bullet meshes. But The MDD isn't supposed to deform with the 2 options (shape retention and lock)
    just made another test, It doesn't work properly, bullet meshes do react to the mdd geometry but interpenetrate it or stay inside It after going trough. Not sure It was that lame before 2018....
    Just for the story, the old dynamic system hard fx, can detect any deformed geometry which had applied the advanced collision to It. How's bullet a progress ? Might be better at simulating but ... how does a tool fit in a production workflow?
    San Jose, CA
    6,717
    What's the "Collision Margin" set to in Bullet for cube and sphere(s)? What scale are the objects?
    Also, what's your "Dynamics Framerate" setting in Bullet->World?
    John W.
    Last test, a 2 m hight mesh, deformed with MDD, collsion: Tried different values up to 100mm
    Spheres: Collision 25mm (they're smaller than the mdd object)
    Framerate is 180, the deforming object solver iteration, I tried several values up to 30
    Same bad results.
    I tried this same exact scene with the of hard fx + advanced collision on the MDD mesh. It works almost perfectly. (and actualy It calculates FASTER!)
    San Jose, CA
    6,717
    Same bad results.
    Yeah, see this thread, apparently Carm3D was told it's a known Bullet issue in LW2018.
    John W.
    ok, cool. Thank you for the link!
    San Jose, CA
    6,717
    This does kind of highlight why it would be highly beneficial for Newtek to maintain some kind of publicly-viewable and maintained "Known Issues in <current LW version>" site (since bugs reports are now basically private to the reporter and Newtek). These "known issue reports", esp. when involving significant issues in features/systems of LW, affect many more than just the person who reported the issue, and currently there's no way for users to even differentiate whether an issue is "already known" or not.
    Expecting "every customer should report every issue they encounter" is wildly unrealistic, customers' time is (at least) as scarce as Newtek employees' time. If Newtek wishes to crowdsource how to prioritize among such known issues, there are much better, UserVoice-type systems they could deploy. Users could easily/quickly vote on or otherwise indicate (depends on system) which issues they consider most important to them, with full analytics, etc. Trying to use bug report quantities as an issue priority indicator just isn't a reliable approach, esp. given the "barriers to entry" that currently exist.
    John W.
