Results 1 to 15 of 26
Thread: Not able to update cgxml files created in Livetext
    Aug 2014
    Miami
    39
    While creating titles on a TriCaster 860 using LiveText, I had an issue where some of the titles I saved as .cgxml files cannot be edited once they are loaded into the Graphics Bin. I was able to create several for a while, but the latest one I have created will not work. Has anyone else had this issue and, if so, how did you fix it?
    Apr 2008
    Racine
    1,660
    Did you save the actual Project in LiveText? If so, go back and check things out and export again carefully to make sure correct export settings were used. Otherwise, I have no idea.
    Jeff
    NYC
    3,333
    No I have not but I've had clients once in a while save a PNG in haste. Look at the file in Windows and see what it's extension as a start. If it's cgxml or PNG.
    As always make sure you are using the latest version of TriCaster.
    Take care,
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    19,397
    LiveText cannot load a .cgxml file, never has ... save your projects as .cg files when you want to keep them in a form you can edit in LT.
    NYC
    3,333
    He mentions after loading into the Graphics bin so I assume no gear to edit the title is displayed but I could be wrong.
    Jose Burgos
    www.burgosfx.com
    FaceBook
    19,397
    Quote Originally Posted by joseburgos View Post
    Absolutely right, José, thanks. I read that too quickly (on my phone, in an airport)
    Aug 2014
    Miami
    39
    Thank you all for your suggestions. I, along with others have checked to make sure we are saving correctly. And correct, I do not get a configuration gear when I open the file in the session. I sent a copy of the project to NewTek and they are going to look at it. I am also going to update the Tricaster Software. I did not have sufficient time to do that before my last show.
    Feb 2009
    Tennessee
    172
    I am having the same problem. I sure need a fix for it as we are going to be adding more graphics to our productions in 2015
    Common Gear Used:
    TriCaster: 40, 460, TC 1
    Time Warp TW42
    Cameras: Sony PXWX70, Newtek PTZ / HX
    Cable Solution:Coax HD_SDI & IP
    Newtek Spark HDMI
    Teradek Cube 105
    Chevy City Express Van
    19,397
    Can you supply a little more detail? OR better yet, a screenshot showing an ineditable file. Does the file icon not show the edit gadget? You could zip up an offending file and upload it here for examination.
    Feb 2009
    Tennessee
    172
    They files are created with the stand alone version of Live Text.. The gear does not show up to edit the titles. I will zip the files when I get back to work
    Common Gear Used:
    Time Warp TW42
    Newtek Spark HDMI
    Teradek Cube 105
    NYC
    3,333
    You did a save as CGXML right?
    Jose Burgos
    www.burgosfx.com
    FaceBook
    Feb 2009
    Tennessee
    172
    Yes I did
    Common Gear Used:
    Time Warp TW42
    Newtek Spark HDMI
    Teradek Cube 105
    Feb 2009
    Tennessee
    172
    Attached is the Live Text file I am trying to use as a CGXML template
    Attached Files Attached Files
    Common Gear Used:
    Time Warp TW42
    Newtek Spark HDMI
    Teradek Cube 105
    19,397
    Hi. I'm a bit puzzled. There is no CGXML file (title page file) in this archive. And it's not a LiveText project file (.cg file) either. Is the .cgxml file possibly one folder higher than the content you included in the archive?
    NYC
    3,333
    Quote Originally Posted by TPUC View Post
    You only zipped the folder that is associated with the page. Please upload the file that is outside this folder you sent.
    Jose Burgos
    www.burgosfx.com
    FaceBook
