Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Electricity, lightning and Plasma effects
    Mar 2014
    Erie,Pa
    77
    What lighting effects is Lightwave cable of doing? I know I can do volumetric lighting and lens flares, but what about lightning and visible electrical current. How about lasers and energy blasts? I've used AE and Motion and it's very limited. Is there another plug-in or software to handle this?
    Bill
    Jan 2004
    Boston
    408
    Here's a real simple electric current/lightning tool. Hope it helps.
    http://www.foundation3d.com/index.ph...13_fileid=1211
    You can get a lot of cool stuff done with procedural textures.
    What I do a lot is make a single null into a hypervoxel and play with the hypertexture settings. Then render out that animation and take into a comp program to further mess with it. You can make some pretty unique fx pretty quickly.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Super Member jburford's Avatar
    Aug 2005
    Frankfurt
    908
    Way back in the day, I played around also using Points and Lines, and applied a mix of jitter on just 1 Axis at a time, then created a Morph for, pulled them all into Layout, and could then use Morph Mixer to animate. But like the examples better. (hmnn, maybe I could have added a Null to mine and used that that pull the Morphs?
    Augusta, GA(usa)
    570
    Hi:
    I believe, there was in the past a cd called lightrom 3, which was packed with lightwave scenes, objects, etc.
    If I remember correctly, there was a plasma effect in it, which was very nice.
    Also there was an old lightwave magazine called lightwavin, which one of them including beautiful lightning fx.
    -Mobilis In Mobile-
    Hmm, the answer is depending from the quality you need. The foundation post is more funny as far realism. Perhaps this helps for reference:
    Animating Lightning Bolts
    https://www.sidefx.com/index.php?opt...2596&Itemid=68
    Lightning are 3D App and comp in AE (glow, blur, etc) equally.
    Axes grinder- Dongle #99
    Seattle
    14,732
    THere used to be a set of scripts from the makers of Vertibevel that had a VARIETY of ways to create lightning effects, some modeler/mesh based, another Layout based.
    Those were the good ol' days.
    (THis is definitely a 3rd party kinda thing-- I don't want dev time spent on this.)
    Here's a more helpful bit of typing: lightning and tree branches resemble each other-- use a plant/tree generator to create complex lightning bolts. I suggest DP-VERDURE from DPont-- free, and allows you to target specific (Modeler) meshes from a root location.
    Create Endomorphs w/displacement and animate between them for the effect. Don't neglect audio , especially for arcs.
    Praise to Buddha! #resist
    I have this tutorial ... very well done and very informative:
    Gary Chike
    Registered User Wickedpup's Avatar
    Jun 2014
    Under the bed
    401
    Maybe you can find some tips here.......
    http://vimeo.com/12745727
    15,096
    I think a lot of people use geometry with transperency and use gradients to light it in some different ways, incidence angles etc.
    the laser stuff..
    https://www.youtube.com/watch?v=JcRlbQZGG7I
    beams like old times babylon 5 sparkles, or star wars racing pod electric connectors, create a polychain with enough points, and displace it with fractals, use glow or bloom for the polychain surface, or add the glow in post process in after effects.
    volumetric lights with textures only and sprite mode can do a lot of cool stuff.
    And some odd force field stuff using displacement on geometry but using hypervoxels on a dense subpatch can yield this kind of effect, never got around to do tutorial on it though.
    Seattle
    14,732
    y'know what'd make a good Liberty3d tutorial? "Innovative Uses for LW's Volumetric Lights". You can get some cool effects out of them, but hard info is difficult to come by.
    15,096
    I suspect many newbies donīt know about volumetric presets to get started even, the problem with that ...you have to enter the volumetric light settings in order to acess it, I hope that the lw3d group someday implement a preset system that can be acessed globally, by that I mean a sort of fx panel or preset panel ..maybe something like maya has, a place where you click on preset panel, and you will open a panel with different folders, like volumetric lights, lensflares, hypervoxels, objects,surfaces, cameras, motion paths, particlefx (where a complete particle rig is setup included with wind dynamics and voxels at one click)
    Simply select item type-volumetric light folder, then drag and drop to the scene, voila instant nebula or laser, no need to add the light and jump in different steps to reach the volumetrics.
    One of the things that annoys me currently, that is partly the lack of improvement in the preset system ..and that there was no such enhancements in 2015, I would be semi satisfied if they removed the annoying "do you really want to replace requester" though that wouldnīt still be enough...drag and drop, then render and you have it done faster than ever before.
    Ehh...tried volumetric lights plasma shield, you click on it, thats one step, then requester says" load settings"...duh? thatīs why I clicked on it, next "warning ...this preset might change the size parameters, do you want to keep the current parameters...sob...sob, I think in most cases I really want that preset applied without reqester steps, reading it, thinking about what it says etc.
    should be an optional choice to set that in the preferences panel I think.
    Michael
    Seattle
    14,732
    Yeah, that whole confirmation stuff is bullsh!te-- i think it's in the damn Surface load too.
    Needs to be an OPTION, at MOST-- really, it's an almost totally superflous click we shouldn't have to do.
    15,096
    yes surfaces is like that too unfortunatly, I want drag and drop, and get on with it, Agreed 100%.
    About volumetric lights though, there are really some nice things you can do for effects with it, and especially pushing it with underlying texture displacement wich distorts the above textures in undulating ways, Ivé used from time to time with nebula stuff, and It can be adapted for electric or plasma fields, for special shapes it could be rendered out as seqences and mapped on geometry if needed.
    Michael
    Seattle
    14,732
    Yeah, it's either a neglected feature or everybody's secret weapon.
    Unfortunately, my underpowered machines make experimentation difficult. Like I said, someone knowledgable putting together a tutorial and presets would fill a gap, but can they make money doing so?
    Back on topic: IMO glowing geometry is the way to go for lightning fx.
