Thread: Help with bicycle rig
    Registered User mijaba's Avatar
    Dec 2005
    florida
    60
    I have a bicycle that I cannot get to stick to the ground. I think it has something to do with "auto origin" being used in the Raycast Geometry setup, but maybe it's the rig itself. The "driver null" is the one with the actual animation attached to it, but it must be raycast so the front and back wheels can reach the ground. At any rate, I've included a labelled picture so you can see where I've gone wrong.
    NOTE-- the surface I have them raycast to and their starting positions are NOT 0,0,0-- if that has anything to do with it.
    Any help would be appreciated.
Name:	bicycle rig labelled.jpg
    Dec 2005
    florida
    60
    I have made 2 dummy scenes (one animated, one not) and have 2 dummy objects (bike and ground object, lorez) for your inspection. Zipped, of course.
    LW bike rigging tests.zip
    Registered User Slartibartfast's Avatar
    Jun 2012
    Sweden
    420
    HI!
    displacing child objects which parent is also displaced is usually a p.i.t.a. Doing it in a longer hierarchy is even worse. The good news is that it's doable! I've modified your scene and attached it. I think this is what you wanted to happen. Basically what I did was to make both "wheel nulls" childs of the "driver null" (instead of one wheel beeing a child of the other, which would add to the node mess )
    Then, the problem with raytracing displacement of child objects is that you get the result as world coords, and to translate that to (parent) object space you have to know the position of the parent. Item info node gives you only the keyframed position so you have to trace it's new position also.
    The ADD 10m node is just there to ensure you don't start tracing below the ground.
    Good luck!
    And yeah, I changed the texture on the ground to a plain procedural, because there was an image lacking in your scene. Ground was just pitch black.
    LW bike modified.zip
    Dec 2005
    florida
    60
    you're AWESOME, Man! Going to try it out right now!
    Dec 2005
    florida
    60
    one last question-- can nodal motion be baked?
    Nov 2003
    jersey
    5,792
    Quote Originally Posted by mijaba View Post
    Sure...
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Jun 2012
    Sweden
    420
    Thank you! My pleasure!
    And RH answered your question
