Results 1 to 15 of 19
Thread: Yosemite and Lightwave 11.6
    Just installed Yosemite on my machine (MacBook Pro Retina, dual graphics card) and have been trying out Lightwave. So far so good. Anybody else have any experience with the new OS?
    Anil
    Registered User RonGC's Avatar
    Dawson Creek, BC, Canada
    562
    Still checking other forums to find out if other apps, zbrush, modo, etc are working ok before installing the new OS. In the middle of a big project and need to be sure all the tools i need to use are working. Good to hear Lightwaves OK!
    would like to update just being cautious, :-)
    Ron
    One user reported my SaveTransformed script was causing Layout to crash. Not sure why as it's just using lscript.
    https://www.lightwave3d.com/assets/p...ed-sequence-1/
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    I've always been here Mr_Q's Avatar
    Burbank
    340
    No issues as of yet. The stupid ALLOW/DENY thing that started showing up since Mavericks is there at launch and annoying.
    Although I will be trying this fix tonight...
    So any OSX users dealing with the annoying since Mavericks and launching apps and getting the ALLOW/DENY pop up with Lightwave and other apps....
    Has to do with digital sigs being munged or out of date...the bypass...
    So if you fire off Terminal and do this per app. Not sure if the* Home\ is unique to this example and can be removed. I was using another script. I will test tonight.
    sudo codesign --force --sign - /Applications/YOURAPP\ Home\ YOURAPP.app/
    Kevin "Q" Quattro
    Inhance Digital
    3D Art Director
    not yet on yosemite (usually wait for at least a .1 release before jumping over to a new system), but never had any issues with what you describe. first run the system asks about it, then not anymore. maybe check your firewall settings about it, could be your system prefs are corrupted. delete this setting for layout/hub/modeler and after repairing permissions and checking for bad prefs, try to launch LW again. should be a one time process to "allow" connections.
    cheers
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
    OSX 10.12.x, macpro 5.1, nvidia gtx 980 ti, LW2015.x / 2018.x, octane 3.x
    May 2007
    Belfort, France
    1,876
    I didn't had the issue Mr_Q describes (neither on Mavericks, BTW). All my native Mac OS apps (even old Quidam 2 !) work fine on Yosemite for me. Some of my wineskin windows app seems to act a bit weird, but nothing too serious ATM.
    Newbie Member eureka's Avatar
    Feb 2007
    Melbourne, Australia
    53
    Blog Entries
    Im having issues, using Yosemite Wacom24HD Lightwave
    Screen flickers and its a pain in the arse..
    Tried reinstalling wacom drivers no luck... any suggestions??
    Submit a bug report. I'm hearing of other issues with Yosemite. Some of my scripts crash LightWave when they don't on Maverick.
    www.ernestpchan.com
    562
    Big projects winding down and Finally upgraded one of my 27" iMacs to Yosemite, kept the other machines on 10.9. Glad i did Shake no longer works past 10.9, so i will keep my 24" iMac on Maverick, i love shake and don't want to lose it.
    Ron
    I had to reinstall a few apps, same versions though?
    Also had to reinstall Rosetta + QT Player 7 from Snow leopard Install and then FCP 7 to get that back up. Could that be the issue with SHAKE?
    562
    Quote Originally Posted by blindsided View Post
    Might be will check it out, Thanks!
    Ron
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    I've just downloaded 11.6.3.
    Unzipped the package and double clicked the installer......... and nothing happens.
    On 10.10 Yosemite
    Help?
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    Quote Originally Posted by JoePoe View Post
    On 10.10 Yosemite
    Help?
    Yosemite won't let you open apps made by "unidentified developers" for security reasons...This might help
    Good luck.
    Jun 2006
    LISA
    1,969
    Quote Originally Posted by Kuzey View Post
    Good luck.
    Yeah, I've been installing stuff all day and ran into that right away. I've been using the "install anyway" button in security prefs.
    It's worked on all the other applications/installers (in fact I've installed older LW versions already) and it seems to work on LW 11.6.3 installer. The "nothing" happens (or doesn't happen) after that step..... at least it seems that way.
    Maybe something to do with the difference between .dmg and .app?
    couldn't you just drag and drop an old install from somewhere else, theres only the app folder to go in applications and the user directory that goes in users library, app support writes itself on first launch ok probably a few prefs files in prefs but again self writing i would think, how hard can it be ?
    @ Blindsided, how the hell do you install Rosetta on Yosemite
