Thread: Rendering Problem
    Rendering Problem
    Hi All
    Can anyone tell me why when I render and object in the main lightwave window it always resets the object, I position it correct and then when you render it turns and moves the object into the default position.
    thanks
    Mark
    Registered User mattbolton's Avatar
    KS, USA
    208
    You must keyframe the position of the camera and the object whenever you move them from the default positions. Easiest way to do this is by pressing the ENTER key twice after you have finished positioning each item.
    Beyond Reality WizCraker's Avatar
    Clovis New Mexico
    1,410
    You either need to turn on Auto Key or hit Enter in order to put a Keyframe down the the Timeline. If you do not do this when you render or deselect the object to work on another item in the scene it will pop back to orriginal position.
    ImageReality.com
    "Relax...it's just an update for the patch to fix the nerf that nerfed the fix for the update of the patch that broke the fix that was fixed."
    Late 2013 MacPro 12 Core
