Results 1 to 1 of 1
Thread: TriCaster SD- Lost Admin Panel
    Applies to: TriCaster Duo, 100, Studio, Broadcast
    Problem Description and Steps to Verify/Reproduce
    TriCaster is missing its default “Admin Panel” buttons (normally visible as the background of the Windows desktop.
    Steps to Fix/Workaround
    Exit the TricCaster software clicking the X in the upper right-hand corner of the interface and select “Admin” from the window that pops up.
    1. At the Windows/Admin desktop, Right Click in any Blank Area of screen and from the pop-up menu that appears select Properties.
    2. Click on the Desktop tab at the top of the Desktop Properties Window.
    3. Click the Browse button and Navigate to:
      C:\TriCaster\AdminPanel
    4. Select “Index.htm” and click Okay.
    5. Then Click Apply at the bottom of the “Display Properties” window, follow up by clicking Okay once more to exit.
    NewTek Customer Support
