Results 1 to 1 of 1
Thread: TriCaster SD- Interface locks on Edit Media Tab
    Moderator
    earth
    203
    Applies to all Standard Definition TriCasters
    Problem Description and Steps to Verify/Reproduce
    -Problem Description
    Tricaster interface locks when clicking on the Edit Media Tab. This may be due to an error occurring during the cache writing process.
    -Specific Symptoms
    1. Launch Tricaster
    2. Click on the “Edit Media Tab”
    3. Did the User Interface freeze or lock up? If so then continue.
    -Verifying and Reproducing
    After launching the Tricaster Software, by default you are in the Live Production environment. Along the top are additional tabs for your video production needs. When clicking the Edit Text tab, the interface locks up. You are no longer able to click or select anything with the mouse. The mouse cursor is still visible & moveable.
    Steps to Fix / Workaround
    Clear the TriCaster Temporary files
    1. Go into admin mode. To do this, click on the [ X ] in the upper right hand corner of the interface. When the smaller window opens, select "Admin” (or if the interface is currently locked on your keyboard press (Ctrl+ ‘V’ + ‘T’)
    2. Open My Computer
    3. Go to “D:\media\clips\Newtek Info” folder*
    4. Open the “NewTek Info” folder then hold down Crtl+A (this will highlight everything) then hit Del on your keyboard.
    5. Close the window and run “Reset Configuration” located on the desktop.
    * If you do not see a NewTek Info folder it is probably set to be hidden. You will need to do the following before completing steps 4 and 5.
    A. Click-on Tools at the top of the window from the drop-down menu select “Folder Options”.
    B. In the “Folder Options” panel click-on the “View” tab.
    C. Click-on “Show hidden files and folders”
    D. Now click-on “Apply” followed by clicking-on “Ok”.
    NewTek Customer Support
