Results 1 to 8 of 8
Thread: Letters Fly to Random Point in Point Cloud - DP Part Move??
    Hello,
    I'm completely stumped on this one.
    I'm looking to make individual letters "Fly" off a page, one-by-one, (probably best driven by a distance Null setup?) and connect to a random point in a point cloud.
    I've watched Bryphi77's Domino tutorial on YouTube (http://www.youtube.com/watch?v=fZloi...PzdWZlKfzF1WRw) and although his outcome isn't exactly what I want and he uses instances I thought it was a good starting point.
    I'm not sure whether I can space my letters out in Layout or Modeler to form the words I want and then use Part Move on them but I think I might be able to use Part Info and a Null. Would you say that sounds feasible?
    My biggest headache, however, is getting the letters to "Fly". Even though the tutorial is incredible in depth, when I plug a gradient Node into the tree to blend between the parts being at their base positions, to their position on a random point it throws the base position out and makes the parts move to random positions nowhere near the point cloud. Below are a few screen shots of my scene and Node tree.
    Text starting position (after initial part move)
    Text connect to random points
    Text starting position (after initial part move) when connected to a gradient
    Node tree
    If anyone could help me I'd be incredible grateful.
    Thanks,
    David
    Registered User Slartibartfast's Avatar
    Jun 2012
    Sweden
    419
    I hardly recognize what you want to do, but attached is a scene where you can make a null adhere to a particle or another null, or somewhere in between. All controlled by a keyframed controller null. Maybe you can use this do accomplish what you want.
    Good Luck!
    mixpositions.lws
    Axes grinder- Dongle #99
    Seattle
    14,732
    That issue (" blend between the parts being at their base positions, to their position on a random point it throws the base position out and makes the parts move to random positions nowhere near the point cloud. ") sounds familiar... I think Bryphii actuall addresses it in a similar tute (same tute?) Something about having to subtract the offset....??? Compensate for ....??
    When watching Bryan's tutes it's a Really Good Idea to take timeline notes so you can find details that otherwise would take hours of searching.
    Praise to Buddha! #resist
    Flocking can do this.
    Open up the Flocking panel.
    Add New -> From Scene Items -> Generator Mesh Polys/Points? (I dont know exactly)
    Select your destination object, your point cloud and
    Add New -> From Scene Items -> Director Goal
    Now under Agents tab play with Range, Cohesion range, Match velocity, usually the lower you set these values
    agents get closer. I have tested flocking recently. It can be tricky sometimes but you cant do this with particles.
    And save Pfx instead of cache. There is a bug I have already reported.
    --Edit--
    Question is now of course: How you attach your parts to the flocking agents?
    Seattle
    14,732
    Something from DPKit, no doubt.
    3D & FX Animations DAMAKERS's Avatar
    Venezuela
    114
    Hello David
    Bryphi77 have a tutorial were he makes letters fly from a text to a point cloud using dp nodes, maybe is what ur looking for
    Heres the link of the first part
    https://www.youtube.com/watch?v=U_AMuRBIwmg
    Thanks for the info. everyone - and the scene file, Slartibartfast.
    Sorry if I wasn't too clear in my initial post.
    I'm basically looking to animate text pealing off a page and then group up with a cloud of text swirling around in a room.
    Here is a concept of what I have in my head:
    I was hoping to combine both Bryan's Domino and Tornado tutorials to create the effect but looked at Flocking when I got a little stumped with DP Kit. Hit the same question as bazsa73 though: how to attach the parts? jeric_synergy, as you say, I'm sure there is probably something in DP's bag of tricks that will do the job.
    This is just a personal project and I'm only jumping into it when I have the time. Will take another look at Flocking and Bryan's node tutorials, it's probably something I'm just overlooking.
    I'll update this thread with my progress if anyone is interested.
    Thank you again,
    David
    P.S. Thanks DAMAKERS, I viewed that tutorial playlist some time ago - I don't think it is exactly what I want but I may be able to take something from it.
    Jun 2012
    Sweden
    419
    Quote Originally Posted by dwalker_88 View Post
    Not tested thoroughly due to work, but here is a setup that appears to do that:
    part_to_particle.zip
    It's a nodal displacement with DP part move
