Thread: What's this?
    Jun 2012
    Los Angeles
    71
    What's this?
    During our last football broadcast, Output 1 (connected with TimeWarp) recorded out replays, Output 2 recorded out Program. Each replay recorded with this strange black bar on the right side of the frame:
Name:	Black Matte on R Side.jpg
    It did not appear in the preview window of the source, but was recorded on the hard drive like that. Anyone know how that could happen?
    Thanks in advance.
    Max
    What video from the TriCaster did you have going out Output #1? An M/E? If it was an M/E did you verify that none of the A&B channels in the M/E had positioning controls turned on?
    Typically, I would setup my outputs the the other way around. My primary record would be Output #2 which would a M/E or at the very least a clean feed for the Timewarp to use. Then use Output #1 as you normally would, as program out. Not that the way you are doing it won't work, but I like to think of Output #1 as program out.
    Jun 2012
    Los Angeles
    71
    Typically, I, too, would want Output 1 to be Program record. However, I'm using a TimeWarp on a TC460. Doesn't it default to using Output 1. Because of that, I have Output 1 as an M/E so I can change the source I'm replaying. I had checked and there was/is no positioning controls turned on.
    I was told today by Newtek to update my software. Hmmm....
    19,454
    Check the Edge controls, as well ... and any active KEY channels in the M/E.
