Thread: 7.5C upgrade problem with MasterHandler
    I recently upgraded my 7.5 to 7.5c and subsequently began recieving this message when I load old scenes I'd built with BRDF shader in them...
    "no plug-in of type MasterHandler found with name .BRDF2. Would you like to load it from disk?"
    Anyone know what's happened here? Is my install corrupted or something?
    Re: 7.5C upgrade problem with MasterHandler
    Dude, I'm having the exact same problem on the mac side, and I am flummoxed...I've used Scan Directory to load my plugs, I've tried trashing the LW prefs and re-loading the plugs using scan directory, but to no avail. Plus, I've gotten some wacky numbers on the amount of plug ins loaded; usually 331 from 119 files, but once was told that 409 Plug-ins were found in 3502 files, a wacky number...
    One glimmer of hope, tho, is that when I load one particular scene in the group I'm working on, that scene does seem to acknowledge or remember where this plug-in is, but others using the same model just can't seem to remember that plug-ins. So, my hope is that I can recreate those scenes and be back on track.
    All I can offer here is a "me too" on the experiencing the problem front..maybe someone else will have the fix.
    J
    _______________________________________
    Discuss sustainability at www.ThinkPlan.org
    What I ended up doing is manually copying the plugins to the plugin directory whenever I saw this bug. It only happened on one or two plugins... it was annoying but it eventually quit happening. LW was pointing to the right directory but the missing plug-ins were elsewhere and a quick search via windows clued me into thier whereabouts.
