Thread: Vse
    Feb 2009
    Tennessee
    172
    Vse
    Is the VSE worth the cost? How well does it work and can you edit the stock livesets with it?
    Common Gear Used:
    TriCaster: 40, 460, TC 1
    Time Warp TW42
    Cameras: Sony PXWX70, Newtek PTZ / HX
    Cable Solution:Coax HD_SDI & IP
    Newtek Spark HDMI
    Teradek Cube 105
    Chevy City Express Van
    Jan 2013
    Florida
    353
    You can edit some of them and that usually is restrained to changing colors, adding logos in some sets and changing background images in some sets. Where VSE really shines is it's ability to allow you to make your own sets, but that requires Photoshop, some 3d modeling/surfacing knowledge and a lot of trail and error.
    Gear Used:
    TriCaster: 40
    Cams: Panasonic AVCHD
    http://studio.ourtrainingacademy.com
    Newtek User since VT2.0
    If you look in your the Add-On icon on the TriCaster home screen, there is a trial version of VSE that you can play around with to see what all it will let you do. The VSE 2.x trial will let you do everything except export a set.
