Thread: Add Roughness to Shadow Catcher
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,708
    So, I've been playing around with camera tracking and compositing with an old version of PFtrack and LW.
Name:	Screen Shot 2014-09-10 at 15.34.54.png
    I've managed to get a good track, exported it to LW, and used the old Null to Points script to make a suitably deformed shadow capture object to match the flow of the terrain. You can see the nodal setup I used to get the shadow colour correct, using a front projected, colour corrected, image sequence, and that's all pretty good to be going on with, (yes, I know the model needs more work on surfacing! ).
    Currently, the scene is lit with a dome light set to 1º, to soften the shadow up a bit, but I would like to simulate the roughness of the grass a little better, just to break the shadow up a little more. Turning up the Roughness in the SC node does sweet FA, so short of cranking up the subpatch level of the shadow catcher poly's, and adding a textured displacement, is there anything I can do to make things look better?
    cheers
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
    Quote Originally Posted by pinkmouse View Post
    cheers
    Could you do something like this?? I went drastic so you see the effect.. The image is front projected for the mapping.
    I was thinking of the immortal words of Socrates - "I Drank What??"
    South Yorkshire
    1,708
    Yes, that sort of works, though I think I'd add a reverse falloff so only the edges are affected. However, I tried with the displacement, but once I'd added a little motion blur and AA the result was barely noticeable.
Name:	Screen Shot 2014-09-11 at 00.13.12.png
    Al
    My Website
