Some things to consider:
- Usually, as in the case of software rental for many businesses, rented hardware is on an as-need basis. IOW, short term when under a crunch is where it makes the most sense.
- Any data that you have would have to be transferred off and the rented drives wiped before you return it. Otherwise, you'd use external drives for data or add your own internal drives that you can then remove easily. You'd need to learn if you can do these additions of hardware without violating their terms.
- Many applications are default installed onto the %SystemDrive% in /Program Files. You'd also have to ensure that no remnants of them are left on the drive or you're risking your software licenses. To minimize this, a Restore Point created (and archived so it doesn't get auto-deleted) when you get the box would help in returning it to close to its original state. Uninstall all of the applications first, then restore from that first clean snapshot.
- With a self-built box, you get exactly what you want; surgically chosen and first-person assembled. This may not be possible with a rented unit, as they will have their own preferences; mostly based upon price and volume purchases. When something goes south, the rented box will have to go back to them for repair. With your own box, you know how it is built and can repair/replace/upgrade at will on your schedule.
We always buy all of our equipment. Loss of control of business related hardware isn't an option. We do a bit of wide format printing for ourselves and for other artists, both 2D/traditional and digital/3D reproductions. Rather than deal with service bureaus that just couldn't
ever match colors (grossly off—
Did you even LOOK at the proof we gave you?), the wait time—often impacting
our deadline, we invested in an 11-color 44" Epson 9900 and rid ourselves of all of that. We can print at 04:00 if we need to and ship that day. Not a direct analogy to a computer, but you get the idea.
As has been suggested, if it's a rendering bottleneck, an online render service would be a good option. Because it isn't physical delivery, one downside of the printing example, above, is removed.
