Results 1 to 8 of 8
Thread: What to do?
    Great State of Georgia
    423
    What to do?
    I am attempting to drill. Most of the radial arms have been drilled but on one occasion I got the following message,
    "Unable to regenerate contour.
    This may be caused by highly non-planar polygons,
    Or by ambiguous overlap between polygon edges and the cutting tool.
    Triple non-planar polygons or add a small offset to data and try again."
    I am attaching an image showing the attempted drill with the message and another with the entire object.
    I'm not sure what the message means. Any help is appreciated.
Name:	Drill tool scene 1.jpg
ID:	123712   Click image for larger version.
Name:	Drill tool scene 2.jpg
    Enjoy Life, this is not a rehearsal!!!
    I usually see this error when trying to boolean subtract objects. The fix is usually to nudge either your cut object or your base objects a mm or 2 in any direction.
    In this case though, I don't think that's necessary. If I am understanding the picture correctly, I think you could probably just grab the cap polygons, bevel them (inset only, no shift), delete the inset polygons then manually bridge the resulting pieces.
    [edit] nevermind that last part, I stupidly didn't think about the intersection in the center. [edit]
    -Joshua Jorgensen
    Axes grinder- Dongle #99
    Seattle
    14,741
    Your cutter object has a lot of geometry--- try reducing that.
    Is the interior intersection VISIBLE in the animation? If not, I'd do as mcb says above and just bevel the ends in.
    Praise to Buddha! #resist
    Dec 2004
    San Juan Island
    4,686
    I've gotten this a lot. Things to be aware of with Booleans:
    • You cannot cut through a point. Points are... points. They have no dimension, therefore, they cannot be split in two. This is what is behind meatycheezyboy's advice to nudge.
    • The error message can also be a result of cruft in the geometry. Be certain that both objects are sound. IOW, no holes, no coplanar polys, no overlapping polys, all polys correctly facing, etc.
    • Sometimes the Speed Booleans will work, where the original won't.
    Aug 2006
    S
    3,511
    I agree with chuck, just bevel the ends. Drill is part of an oldish toolset i.e. LWCAD cuts into n-gons.
    Attachment 123733
    Seattle
    14,741
    If the holes need to go all the way thru, making them BEFORE copying/rotating the bits around will be a lot easier.
    Unless you're doing some fancy stuff with the exterior chamfer.
    Professional amateur Amurrell's Avatar
    Dec 2005
    Lincoln, NE
    1,350
    Also, you can force polygons into being planar by tripling your polys. Sometimes just tripling your cutting object is enough.
    --Andrew
    Bono Animo Esto
    Intel Core i5 3570k
    nVidia GTX 970
    8GB DDR3 1333MHz
    Windows 10 Pro 64bit
    pass:sword OFF's Avatar
    Russia
    1,098
    you can split your object into pieces and over each individually do your Boolean operations. it helps on the difficult, complex models.
