Results 1 to 8 of 8
Thread: Turn a $5 US/month linux VPS into a ScreamerNet render node?
    Discerne.com CEO caesar's Avatar
    Jun 2003
    Piracicaba, Brazil
    741
    Cool Turn a $5 US/month linux VPS into a ScreamerNet render node?
    ...I know thatīs a ScreamerNet Forum, but I think posting here will get more views...
    With Linux boxes (VPS) starting at $5 US/month at Digital Ocean (1 core, 512 mem, 20 GB SSD and 1 TB bandwidth, all the way to 20 cores and 64GB of RAM!) as well others providers like Linode, would it be awesome to use them as render nodes?
    Could someone at NT or the community made it happen?
    This VPS are 1 click set up, they charge by the hour so you can add/lower hardware just as easy (it just needs a reboot, again just a GUI click), you can map a drive in your local machine to sync with the server using a SFTP app, all encrypted on the fly.
    They have a new API, so any Python artist can set buttons inside Layout to control the whole process.
    I think it can be the cheaper solution to get render nodes today. What you think?
    Moro num pais tropical...
    Discerne.com - personal blog
    Jun 2003
    Piracicaba, Brazil
    741
    In my little research, installing LW in Linux is doable, and act as a render node too. The problem is that ScreamerNet only looks for nodes in a local network, and I think it's not possible to choose a specific machine IP, or use something to map a different IP to a local one (proxy server?). Maybe too complicated, or another tool can do that?
    Jun 2014
    Right here
    1,692
    Hi Caesar
    Sorry, I don't think this is worth it. First of all some emulation software like Wine would be needed, additionally a ScreamerNet configuration as 1-click app :-). I don't think they are interested in an application consuming all the CPU power, maybe (most likely) the CPUs / Cores / RAM are only virtualized, I didn't see any information about what technology they're using (maybe servers with Atom boards? Then you can forget computing power, not to mention floating point performance etc.). And what LightWave scene would you render with 512 MB RAM that you cannot on your normal computer? If you go for a more capable configuration (4 cores, 8 GB RAM) it costs you $80 per month (still not clear what one core means). I think you're better off with a normal PC / Mac using a modern Core i7 or similar processor with 8+ GB RAM, that's probably cheaper than one year renting this cloud service. If I would really require high computing power one day I would look for professional rendering services that already have all the software ready up and running and they are prepared for 100% CPU load.
    Cheers, Marander
    Jun 2003
    Piracicaba, Brazil
    741
    Thanks Marander for your thoughts, it makes sense.
    I managed to find out Digital Ocean uses Xeon 6 cores, 2 to 3 Ghz (https://www.digitalocean.com/help/technical/general/), here's one from a 5/m setup:
    processor : 0
    vendor_id : GenuineIntel
    cpu family : 6
    model : 62
    model name : Intel(R) Xeon(R) CPU E5-2630L v2 @ 2.40GHz
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    cache size : 15360 KB
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq vmx ssse3 cx16 pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm xsaveopt vnmi ept fsgsbase tsc_adjust smep erms
    bogomips : 4799.99
    clflush size : 64
    cache_alignment : 64
    address sizes : 40 bits physical, 48 bits virtual
    power management:
    Not that bad?
    I agree that 512m is too low, that's why I mentioned that you can set RAM, proc on the fly and hour charged, so thatīs advantages to go cloud. I still don't know about using 100% CPU time restrictions, but they don't mention nothing about it (as Rackspace does it).
    Maybe for now it could look not ready, but there's a lot of areas being revolutionized by cloud computing/services (I can mention great new technologies like Docker, Vagrant, MongoDB, Cassandra and NodeJS), just take a look at Lagoa Render, I think it has place for Lightwave too.
    Jun 2003
    Piracicaba, Brazil
    741
    Iīll post below a 32 GB, 12 proc specs (sorry about the length), $320US/month.
    It took 60 secs to it be usable, with Ubuntu 64bit. I can use that for 2 days, and then "destroy" the machine. That's bring flexibility, so you can get more/less power adapted to your jobs.
    processor : 0
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 0
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 0
    initial apicid : 0
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 1
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 1
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 1
    initial apicid : 1
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 2
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 2
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 2
    initial apicid : 2
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 3
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 3
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 3
    initial apicid : 3
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 4
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 4
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 4
    initial apicid : 4
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 5
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 5
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 5
    initial apicid : 5
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 6
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 6
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 6
    initial apicid : 6
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 7
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 7
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 7
    initial apicid : 7
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 8
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 8
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 8
    initial apicid : 8
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 9
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 9
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 9
    initial apicid : 9
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 10
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 10
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 10
    initial apicid : 10
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    processor : 11
    cpu family : 6
    model : 62
    stepping : 4
    microcode : 0x1
    cpu MHz : 2399.998
    physical id : 11
    siblings : 1
    core id : 0
    cpu cores : 1
    apicid : 11
    initial apicid : 11
    fpu : yes
    fpu_exception : yes
    cpuid level : 13
    wp : yes
    bogomips : 4799.99
    clflush size : 64
    power management:
    Jun 2014
    Right here
    1,692
    Hey Ceasar
    These specs really look fine, thanks for verifying. But the price... But if it's for a limited time and they don't mind full cpu usage there might be a use case.
    Have a nice day and best regards to Brazil,
    Marander
    Jun 2003
    Piracicaba, Brazil
    741
    Hey Marander
    I agree it could help in a project, but for now render farms could be the only choice. I'll keep watching about the subject.
    Cheers.
    Registered User calilifestyle's Avatar
    Jun 2006
    cali, Santa Clarita
    1,561
    Blog Entries
    4
    I think once SqiudNet add cloud rendering it will make it a lot easier to do this kind of thing. I tried setting up EC2 render node but i kept getting errors.
    Ell no 'ta enamora' de mi, yo tampoco
