Thread: noise in input 1 mic tricaster
    Jun 2012
    peru
    379
    Hi, i have a problem with a noise in tricaster, I connect the program output of my audio mix to tricaster ( input 1 - XLR conectors), tricaster was setting with input mic 1,2
    I notice that in the stereo channel side L have a noise, something like when you increase to much the gain of the input, and the other side R have a different an more notice sound , something like a bip ( seems like the test tone when you have bars)
    i disconnet the input of tricaser so, now there is not a cable connected to tricaster , but noise are present, the bip is very anoying more than the other sound.
    the lvl of indicator are in 0 db. and noise is present, i have to decrease under 0 db the lvl of mic 1 in order to dissapear the noise, but our recording is very low.
    what could be the problem?
    PD: when i choose line input in this input 1 noise dissapear. only present when mic is selected
    Gear Used:
    Tricaster: All 3Play:440
    Cam: JVC GY-HM600, GY-HM150U
    Facebook
    Twitter
    Once more into the CPU!
    Oct 2006
    Port Orchard, Washington
    442
    What model TriCaster do you have and what's the make and model of your audio mixer?
    TC Mini SDI 5-1-190425
    -BlackMagic Studio Cam
    -SDI cables
    -Spark SDI
    -LiveText w/SB2
    -YouTube Stream
    _
    SKTV 205
    https://www.youtube.com/user/SKHSVideoProduction
    Oct 2012
    Munich, Germany
    80
    Hello,
    I can't help with the noise but have a note on your description of the setup.
    Why do you set a input to mic level when a mixer output is connected ? Mixer output are usually at line levels.
    best regards,
    Walter
    PS: regarding the noise, maybe a mic input amplifier is damaged on your machine ?
    TC8000 / TW850
    Cables: Belden 1694/Canara Connectors
    Cams: Sony PWM-EX3, Sony HDR-CX430/BMD HDMI2SDI
    Jun 2012
    peru
    379
    thanks both for answer
    the model of my Mixer is Yamaha MG166CX 16-Channel Mixer and tricaster 460
Name:	tricaster yamaha.jpg
    I connect to mic output because is balanced and the level of audio is high? i'm afraid that if connect with TRS connectors have problems with noise and low level audio
    I don't know so much about audio, do you recomend that use plug connectors on the output in yamaha and input of tricaster?
    Gear Used:
    Facebook
    Twitter
    Registered User bbailey's Avatar
    Jan 2009
    Odessa, Texas
    514
    Sounds to me as if you were over driving your TriCaster audio input. The output of your mixer is more than likely at line level and will definitely over drive a mic level input even if the VU looks correct. Sounds as if all you need to do is set your TriCaster's audio input to line level input rather than mic.
    The cabling should remain the same. You may be thinking that because those outputs on your mixer look like a mic cable should plug in there, that they are mic level. That's not true. Some Mackie mixers have a push in switch that allows for the XLR outputs to be EITHER mic or line level. But if your Yamaha mixer doesn't have that switch, your outputs are line level.
    You're using an XLR-F on the cable coming out of your mixer with an XLR-M plugging into your TriCaster. Just go into the audio channel's drop down menu on the Tricaster and select Line as the input type and you should be good to go.
    Tricaster 860 and CS
    3Play 330 and CS
    Sony PMW-EX3 HD-SDI
    6-Sony HXR-NX5 HD-SDI
    Sony Z1-U Component to HD-SDI
    GoPro Hero4 HDMI to HD-SDI
    Post-Production FCP7 & FCPX NLEs
    2-AJA KI PROs
    Jun 2012
    peru
    379
    tanks every body masters =). know i understand what Labmaster said.
    yes Mr bbailey i was thinkg exactuly as you describe, i changed de setting from mic to line, so far it looks good.
    thanks for the support
    Gear Used:
    Facebook
    Twitter
