Results 1 to 1 of 1
Thread: Output Connections: A/V Output 3Play 4800/440
    Moderator
    earth
    203
    3Play provides several video and audio output connector groups, and very flexible options for display of your live and recorded video streams. Here are some of the possibilities:
    • Simultaneously send two indpendent outputs to extneral devices.
    • Send 3Play audio and video output to a network-connected TriCaster ™.
    • Simultaneously send output to both analog and digital devices.
    • Transmit another output or multi-bridge monitoring layout to a secondary monitor (or projector) via the Multiview port.
    • Another output option is provided via an HDMI port. This output tracks the active 3Play Channel Delegate (A or B).
    • Finally, two Display ports provide Channel A and B video to two further computer style monitors.
    NewTek Customer Support
