Page 2 of 36 FirstFirst 123412 ... LastLast
Results 16 to 30 of 531
Thread: RHiggit 2 discussion thread
  1. #16
    I think part of my problem is it isnt working in 11.6.3...AFAIK
    The spacer is added at the shoulder, but the rotation isnt applied to the spacer joint....
    when I add it in 11.6.2 the rotation is also applied to the spacer joint (the center of rotation is the center of the joint)
  2. #17
    Nov 2003
    jersey
    5,771
    Yes, 11.6.2 is rpeferred at the moment. If you've not seen or got the 202 update for this, grab that also.
    Cheers.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
  3. #18
    Heffalump
    Away
    3,897
    Quote Originally Posted by m.d. View Post
    11.6.3 and 11.6.2 should be identical - the only change was for licensing. That's very odd.
    Inactive.
  4. #19
    could be me...not ruling that out
    but several attempts at both, and it only worked in 11.6.2
    it might have been that because one control is directly under another I was clicking both....??
  5. #20
    What is the recommended FBX workflow with Rhiggit 2....I know we had RH FBX rigs prior to version 2
    I would like to animate in motionbuilder and bring back into lightwave....I know we can retarget, but that is an extra step and probably not 100% the best solution if we will always be using MB.
    Does the deform rig export nicely into FBX for MB?
    EDIT: i will be using nulls deform rig
  6. #21
    Nov 2003
    jersey
    5,771
    Motionbuilder (or other external retargeter) workflow goes a bit different, as none of the rigs now (unlike v1) contain an fbx style "input" control. You can't use the actual deform rig itself (well, you could, but it'd be bad). The way to do it... at least for the moment, is to just make a plain, fbx style skeleton (or just use the one from here... http://www.rebelhill.net/downloads/LW-FBX.zip ) and snap position it to the joints of your RHiggit rig. Give it a mesh copy if desired, etc, and export it out. Do your retargeting, bring it back into LW, then use the RHiggit retargeting to take the animation from that skeleton back to the RHiggit rig.
    RHN Nodal Tutorials
  7. #22
    Nov 2003
    jersey
    5,771
    Also...
    V2.03 is up
    RHN Nodal Tutorials
  8. #23
    Thanks, makes a lot of sense.....if the FBX rig is snapped to the same positions as the rhiggit rig, the retargeting should be near perfect.
  9. #24
    Nov 2003
    jersey
    5,771
    Yes... the retargeting functions in RHiggit will still retarget the motion... but given that the skeleton an exact match (proportions wise) you should just get a straight 1:1 transfer of the motion. I've also got a tool on the cards to automatically spit out an FBX skeleton that's matched to your RHiggit rig, which'll speed up the process too, that'll be along at some point, with some update release or other.
    Cheers.
    RHN Nodal Tutorials
  10. #25
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,525
    As mentioned up stairs... Rhiggit! v2.03, LW 11.6.2
    Eyes / Eyelids in Standard Biped are targeting head_end marker, not eye targets. Targets need to be set manually to fix.
    However, I do net get the critical error reported after a clear scene. After clearing a scene, Rhiggit2 generates a rig without throwing any exceptions.
    My Scripts for Lightwave
  11. #26
    Super Member Kevbarnes's Avatar
    Nov 2006
    Gloucestershire UK
    509
    might be just my machine, thanks
    just getting 2.03
    "one rig to rule them all"
    PC Spec: Intel i7 X980 3.33GHz | 24Gb | ATI FirePro V5800 | W7
    https://vimeo.com/kevbarnes/showreel
    https://littlstar.com/kevbarnes
    https://www.talenthouse.com/kevbarnes
  12. #27
    Nov 2003
    jersey
    5,771
    Okies... so that lil eye thing is fixed... v203-b
    As for the crash thing... Ive seen this aplenty, but its far from "predictable". Ive had occasions where I launch LW afresh, bring up bodybuilder, and it crashes out. Othertimes, I can go through a number of clear scenes, bodybuilder, etc... and have no problems. Ive literally got no idea what it could be... but has to be some lil hiccup in LW itself. Perhaps its the "switch" between the 2 different panel types, perhaps its a memory leak thing, or items getting "lost" from memory (RHiggit builds a set of multidimensional arrays while working which carry the "rig" as a kind of data object). However, because its slippery as it has been, it makes it hard to track down, and thus fix. Also, since Ive only had it happen to me either when launching a brand new rig, and never whilst actually working on something, it might prove to be a bit of an inconvenience, but shouldnt cause you to lose work part way through.
    Cheers.
    RHN Nodal Tutorials
  13. #28
    I've got a crash that happens 100% of the time....
    Run rhiggit on a character in a scene.
    Clear scene
    Load same character lwo into new scene.
    Run rhiggit.
    LW needs to close inbetween and it works fine...if not .....crash every time
    Not a big deal, but maybe helps track the bug
  14. #29
    Feb 2009
    Prescott, IA
    1,525
    A suggestion, then, for 2.1, or 2.5...
    Convert it over to Python. That way, we can get some traceback information off the console to help squash these bugs but good.
    Or convince Newtek to add some serious debugging stuff to lScript.
    Rhiggit! 2.03-b, LW 11.6.2
    -When adding digits to the head, they appear @ world <0,0,0> instead of somewhere near the head marker.
  15. #30
    v203-b IK/FK switches do not have constraints and IK/FK switching does not appear to work with fingers? Anyone else??
    - - - Updated - - -
    Constraints work if U add the fingers in "Digit mode" not in "Arm modes". IK/FK blending is not working right for the fingers
