Thread: newbee question about center pivot in layout
    By default, the pivot is the center of the modeler layer.
    If i center pivot in modeler, then i have to move pivot in layout...
    Any way to automatic center pivot in layout based on the mesh center??
    ack ack Markc's Avatar
    Feb 2006
    England
    1,360
    How are you a 'newbee' if you joined in 2003?
    Do you mean you have a number of different layers in the object, but you want the pivot in the center of the object?
    I think the only way AFAIK is to combine all layers to one, select center pivot (Layers-Pivot) in Modeler, then Reset (Modify-General) in Layout.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2019
    Axes grinder- Dongle #99
    Seattle
    14,729
    It looks like this is one of those few things that DOESN'T get updated (kinda like added layers) once you've loaded the object into Layout.
    That is: the LWM Pivot Tool works in LWM and Layout for the first time an object gets loaded. Here, after that first load, subsequent manipulation of the pivot point in LWM has no effect. At least, it's not auto-updated here. It may be that reloading it would work.
    If I characterized that correctly (and I wasn't highly rigorous), IMO that's a bug.
    (and sometimes I'll call my questions a "noob" question because it seems there must be a simple answer.)
    Praise to Buddha! #resist
    Thanks Jeric. Yep i tough that was not working but it was the refresh bug.
