Thread: Weld 2 Points > fastest solution ?
    hi there,
    any ideas to how this could be done faster / better ?
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    You're pretty much explaining the merge tool...select the points you want then merge with the distance option
    See video...I tried it with all 8 points, so you might want to test it with just 2 and see if it works differently.
    Attached Files Attached Files
    Why does this bother you?
    Snap Drag and could have an option to merge when snapping.
    Bridge could have an option to actually weld the loops instead of bridge them.
    An interactive Merge tool would fit just fine there too.
    Cheers
    Quote Originally Posted by Kuzey View Post
    yes, not very fast... :/ Maya method seems faster, but not ultimate...
    probiner
    looks like it did... :)
    probiner
    indeed, those are also good...
    You did not present any Maya method
    Maya is pretty much snapping ;]
    Snap Drag and could have an option to merge when snapping...
    so pretty much that... :]
    but the method i suggested with "merge 2 nearest points only" should be 0.5 seconds faster
