Thread: HELP HELP HELP - Audio Sync out
    Sep 2011
    New Zealand
    24
    Hello,
    When playing back - say an interview - the audio lags and so lip sync is out...even on productions i have finished that were all ok, now when i open audio is out of sync - even when i render - audio still out of sync.
    This is new, never had issues until now...
    My specs are:
    Asus G75V Intel i7 3610qm 2.3ghz
    Seems all new footage does the same
    thank you
    3 press conferences?! 3?! quantumvista's Avatar
    Oct 2003
    Chicago, IL
    136
    If I can help I will. in the interest of full disclosure, I'm having trouble with the Tricasters audio Sync as well but in a Dante environment.
    Hardware specs are informative but we need to know the IO and configuration to get to the bottom of most of these issues. Please provide details about your production system and workflow, i.e., tricaster model, audio system, playout device...
    in other words, How are you recording? What are you recording? and as much info as you can provde about the system.
    Thanks!
    If you're not outraged by all this, then you aren't paying attention.
    Registered User donx's Avatar
    Feb 2008
    Vancouver B.C.
    404
    If something was working and now it is not, sometimes re-installing SpeedEdit will fix the problem.
