Results 1 to 12 of 12
Thread: Making SPIKEY (Tool) Endomorph
    Axes grinder- Dongle #99
    Seattle
    14,729
    Question Making SPIKEY (Tool) Endomorph
    I'd like to make a morph that consists of a tesselated sphere morphing to the same sphere after one has applied the SPIKEY TOOL to it.
    Haven't found a workflow that will make this practical. Is there a way to get the new vertices into a separate Selection Set, or the converse, the Original vertices in a set that the new ones don't inherit?
    (whoa, either found a bug in map creation, or LWM is wiggin' out...)
    Since there didn't seem a way to directly get Spikey to only affect an Endomorph (I only managed to get two spikey versions, the morph AND the base), I used HeatShrink to reconform a Spiked version back to a saved version of the original tesselated sphere.
    Now off to see about morphing Instances....
    Praise to Buddha! #resist
    What about doing the spikey thing on a dupe of your ball and then doing a background to morph operation.
    I'm not following why your morph isn't working unless you're changing the point count. I can't remember what spikey does.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Seattle
    14,729
    Spikey DOES change the point count: it adds a point at the centrum, I believe, of all the polys in an object and then moves the new points along their normals.
    I don't THINK I can store the original, unSpikeyed object to use background>morph, because once you use Spikey the point counts are different.
    And there's some issue with if you HeatShrink the BASE, you lose the Spikey morph because morphing is relative, and LWM thinks the Spikeyed hasn't moved, ie the displacements are zero. So, you MUST HeatShrink the morph, and the Base becomes the spikey version.
    HeatShrink is becoming more and more useful to me.
    Sorry, point count has to match. You could do an object sequence where you swap between the two objects. Not sure how that would work with your Plexus setup in the other thread. Hard to mentally troubleshoot when cashier is talking to me, haha.
    www.ernestpchan.com
    Seattle
    14,729
    Not a problem: heatshrink worked a treat, thank buddha.
    A new version of that oh so very useful Spikey , that put the new points in a Selection Set would be..... well, silly, but nice. Now, THERE'S a low priority item.
    (I should watch it: I remember someone DID find a good use for Spikey, but I disrecall what it is.)
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    If I understand ....
    You can use Spikey , but it's actually adding a step to this workflow:
    1) make tessellated sphere
    2) run Make Pole (This is your base.)... new points will stay selected. (Make set if you want to.)
    3) Use normal move.
    Option two.... using Spikey:
    2) run Spikey at zero%
    3) use point statistics to grab points associated with three polys. (Make set if you want to.)
    4) normal move.
    Make Pole is, essentially, Spikey without the shift.
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    Seattle
    14,729
    Interesting, JoePoe, mucho gracias. I rarely think of/use Make Pole. So that's 2 methods (3 if you include my lame one).
    #awayFromLW Aren't the points created by Spikey connected to >3 polys?
    ObligatoryFeatureRequest: "Selection History", which would store both manual selections and newly created point sets, such as those created by Spikey and Make Pole.
    Jun 2006
    LISA
    1,969
    ...Aren't the points created by Spikey connected to >3 polys?
    Not on a tessellated sphere (puts a new point in the center of each trigon).
    Seattle
    14,729
    I was using a very low frequency tesselated sphere (2?)-- I think it had some pentagons in there. I certainly looked at it, but rejected it. #awayFromLW
    Jun 2006
    LISA
    1,969
    ... I think it had some pentagons in there.
    uhhh, really?? Look again when you're not "#awayFromLW" .
    Edit: you can certainly make some pentagons/hexagons by combining tris...
    Seattle
    14,729
    My mistake. That's what I get for using Wireframe.
    personally, i found the tool to be obsolete...
    JoePoe
    3) Use normal move.
    Dito... \ :]
    jeric
    i use it all the time :] my shortcut > Alt-m
