Thread: Tricaster Control Surface Responsiveness Issue
    Jul 2012
    Wallingford, CT
    32
    Hey all,
    I have a recently restored my tricaster 455 with the fill 460 upgrade due to an un-related issue and taken care of that. My issue is now that my control surface seems to not respond during and not during a live production. When I press "cam 1" button for ex) on the program row is lights up green but will not switch to "cam 1" in the program out. This can happen throughout a production and has happened in multiple sessions as well. I am going out through AUX out only.
    Any ideas as to why the control surface would respond then all of a sudden not respond then respond again?
    Also important to note that this happened before and after the tricaster was restored.
    Alan Billings
    Feb 2010
    Boston
    451
    How is the control surface connected to Tricaster?
    Is it directly with a USB cable? If so, how long is the cable?
    If through a USB hub, is the hub powered? How long are the cable runs?
    Jul 2012
    Wallingford, CT
    32
    The USb cable is the slandered USB cable that was provided by newtek in the box.
    19,482
    In that case, and if a brand new session also behaves badly, you may want to talk to CS. There was a hardware modification that was required for certain CSes, not sure if this will apply.
