Thread: AVID artist mix
    Jun 2012
    peru
    371
    AVID artist mix
    Hi sorry if it's not the correct place to report it.
    I have a avid artis mix with a tricaster 8000, the problem is that i install the drivers of artist and work well, control everything but after we turn off tricaster or restar it we lose the connection, and i need to reinstall the artist mix each time that i reboot.
    someone have an idea what happend?
    Tricaster is the best thing that i've used since I played with my atari
    Gear Used:
    Tricaster: All 3Play:440
    Cam: JVC GY-HM600, GY-HM150U
    Facebook
    Twitter
    What drivers version of Avid Artist Mix are you using? Eucon v3.01 64-bit should be the version to use (not the latest). Make sure you are current a fairly current version of TC8000 software as well.
    Jun 2012
    peru
    371
    Master Kanep hi
    I install the version that u said, Eucon v 3.01, now tricaster link to Artist mix without reboot, work very well, after that i reboot, the tricaster link artist mix well but a error message show, my only alternative is closed it and after that tricaster don't reconized the avid. see image attach
    i will now update tricaster if it can help
    Gear Used:
    Facebook
    Twitter
    I've not seen that error message on my system. Perhaps try a uninstall of the Avid Artist Mixer drivers and then re-install. Did you have a previous version of Avid Artist Mix software installed before v3.01?
    Otherwise, I'd put a call into support.
    Jun 2012
    peru
    371
    Mr Kanep I update the tricaster and then install artist mix V3.01 it work fine now, thanks !
    Gear Used:
    Facebook
    Twitter
    TriCaster 860 PortaStudio
    Mar 2009
    Mililani, Hawaii
    118
    Thanks for posting information on the Avid Artist Mix. I have one ordered and I've been concerned about getting it to do what I want. Do you folks use it just for audio, or are you triggering other things with it?
    The Artist Mix can be used for audio mixer control in the TriCaster. You can't trigger macros from it.
