Results 1 to 1 of 1
Thread: Bringing in HDMI as a source through an SDI converter
    PROBLEM DESCRIPTION and SOLUTION
    In the event you find that your source can only output via HDMI then you will need a converter to get it into your TriCaster. Keep the following in mind:
    • What exactly is your device outputting through the HDMI?
    • Is it a non-standard resolution?
    • It is possible that the source device may not be outputting a stable/legal signal (non-SMPTE compliant)? If so, to resolve this you will need a frame synchronizer, some converters may have this built in. This will force the output of the converter to be SMPTE-compliant
    NewTek Customer Support
