Results 1 to 8 of 8
Thread: Can not rename the UV map. Help!
    I need remove "2" from name and and copy into another map with same name.
    What i do wrong?
    Thanks!
    If I understand your problem correctly you already have a texture map with the name "Audi_virsbuve". That's why you can not rename "Audi_virsbuve2" to "Audi_virsbuve".
    7,891
    Copy Vertex Map, and pick up existing one.
    Then delete old one.
    The object is open alone in LW Modeller with one UV Map. I just like rename that UV Map.
    Is there any other map with the same name?
    Quote Originally Posted by bazsa73 View Post
    Correctly! Two, three times succeeded rename, but now not longer.
    No.
    Strange. If you are allowed, Fogbugz this scene to the developers.
