Thread: Default number in Co-planar Polygon Reduction
    Registered User Remoc's Avatar
    Feb 2008
    Darwin Australia
    126
    Hello Lightwavers,
    I want to change to default Polygon Reduction Deg. from 0.2 to 0 [see attached image]
    I want set a shortcut key to the reduce polys and then only have to press enter for quick reduction. Currently I have to type 0 into the box everytime.
    Where can I change this default number. Is it in a text file somewhere?
    Remoc
    If that tool is a .ls file you could edit it in there.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Feb 2008
    Darwin Australia
    126
    I don't think " Reduce Polys " is a script as it is a core feature, and has been for many years.
    There are a few plugin files with the .p extention which it may be... but I guess one can't edit these as they are compiled??
    Yeah if it's a .p file it's a compiled C plugin file and you're out of luck.
    www.ernestpchan.com
