Results 1 to 8 of 8
Thread: UV Spider Mapping
    Dec 2007
    Irving, Tx.
    573
    UV Spider Mapping
    Hi everyone,
    I'm using UV Spider to map a rope element but when I created the rope I failed to plan for knot placement. I should have selected uniform placement in hindsight. When using UV Spider on this part of the model the points on the map are equal distance regardless of poly size. Some polys on the rope are longer than others but the UV map has the polys being consistent in size. Do I have to redo the rope model from scratch to get better mapping or is there a way to get the map to reflect the unequal poly length? I didn't plan on actually UV mapping the rope but thought it wouldn't be a bad idea. How would you guys tackle this? Thanks for the input.
    Richard
Name:	Screen shot 2014-04-24 at 9.17.15 PM.png
ID:	121612   Click image for larger version.
Name:	Screen shot 2014-04-24 at 8.54.17 PM.png
    Mac Pro Dual Quad Core, 6 GB RAM, NVIDIA QuadroFX 2000 2GB Ram, 2 TB HardDrive LW 2019
    I Wished My Brain Came With A Manual... I could look up everything I've learned sorted by topic...
    If I understand correctly. I'm thinking you could manually (In Photoshop) Stretch "in"
    the texture for each poly to adjust for the distortion. May want to change the Image
    Mode to 16 or 32bits. I haven't tried this but it might work.
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    Use UV Creeper instead?
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    Dec 2007
    Irving, Tx.
    573
    Thanks for the tips. Just downloaded Creeper. Looks like it might be what I need. Will use image adjustments if needed. Thanks again for the very quick responses!
    Richard
    Dec 2007
    Irving, Tx.
    573
    The plugin looks like it installed but can't locate the interface. I'm running 11.6.2 on a Mac. I assumed it would be in the Map tab is this incorrect?
    Richard
    Dec 2007
    Irving, Tx.
    573
    Never mind, I found it. Sorry for the posting...
    Dec 2007
    Irving, Tx.
    573
    Wow, what a useful plugin! Works like a charm. Thank you for sharing the link!
    yes, use UV Creeper... ;]
