Thread: Instance Generator on more then four points polygons?
    Registered User Lucasmorif's Avatar
    Oct 2013
    Brazil
    66
    Hi guys I'm trying to use the Instance Generator on more then four points polygons, but it isn't working. Am I doing something wrong? Is there any workaround or will I have to slice my polygons to four and threes one by one?
    Here's my print screen.
    http://prntscr.com/3cn8wy
    Thanks.
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,154
    You should use to triple command to break your large polygons into triangles.
    Oct 2013
    Brazil
    66
    Thanks lertola2, I used, but the instance generator distributed the instances in a really odd way.
    Los Angeles
    7,241
    Yes, if you use surface mode, you need to use quads or tris. If your plane is an ngon, you might try slicing the object in a grid pattern by using Julienne 2 twice--once along x and then along y--and then tripling or killing any remaining n-gons around the edges.
    G.
    Los Angeles
    7,241
    Also, if you need to the unaltered version of the n-gon in the scene for rendering, make a second version object and slice up the copy. Then, you can disable the sliced version from render in Scene Editor and it will still work as instancer.
    Oct 2013
    Brazil
    66
    Great greenlaw!
    Thanks a lot!
    I'll give it a try.
