Thread: Bones controlled by Spline
    Has anyone had this problem?
    I'm trying to animate an eel along a spline (similar to Lino's shark tutorial) and whenever I turn the spline in a circle (the eel is in a round aquarium) the spline flips the eel 180d upside down. It seems that the spline is pinched and flips over. The only way that seems to solve it is to straighten the spline (which in this case won't work because of the aquarium). I've tried correcting it using bank, but it only goes so far and doesn't solve the problem completely. Am I missing something, or is this how the spline setup is supposed to work?
    It seems to work as long as I don't turn the spline a full 180d (back on itself, hopefully that makes sense). If I make it a complete circle, there are two places that will do what I've described.
    thanks,
    bruce
    ________________________________________
    http://bruceholt.com
    http://bigredmeteor.com
    Nov 2003
    jersey
    5,766
    Make sure to rotate your null handles to "point" along the direction the spline is heading.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    WOW! Such a simple solution to a big problem (for me anyway). Did I miss this somewhere in a tutorial? I had tried rotating the other axis', but I guess I hadn't rotated it far enough.
    Thanks RebelHill!
