Results 1 to 15 of 18
Thread: High Res Textures
    Still Rendering! randysolo's Avatar
    Dec 2003
    Winston-Salem, NC
    94
    High Res Textures
    Can someone point me in the right direction for a good source for High resolution wood textures or images to use for furniture and cabinets?
    They're not that easy to find. Unless I'm looking for the wrong thing.
    thanks!
    Powersolo
    "Play nice!"
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    What's hi res to you?
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    Dec 2003
    Winston-Salem, NC
    94
    I don't know. Maybe 5000 x 5000? I would just like to find some decent wood images I can use for furniture.
    maybe it's best I photograph my own?
    thanks,
    "Play nice!"
    Jun 2006
    LISA
    1,969
    Photo your own? I won't say no to that.
    5K x 5K.... That is pretty big. Apart from the needle in a haystack Google "large" image search, and google "hi res" search, I can't think of anything specific, sorry.
    But I'll keep thinking 'cuz I love the Winston-Salem area!!!!
    Cgtextures not working for you? Just sign up to register and get 15 mbs of images per session. The really large textures you have to sign up as a premium member ($) but the lower sized ones can still be pretty big.
    16,788
    yeah..cg textures might have some...for free, otherwise for high quality if you can pay for it, maybe http://www.arroway-textures.com/en/products/wood-3
    hereīs some free ones, might need to log in for some of them, and some might not have enough resolution, but there are different sets...
    http://www.tutorialchip.com/freebies...wood-textures/
    textures are prefered, but you might wanīt to check procedurals, though they might not always be onpar with true textures, you donīt have to worry about resolution though, only render time since procedurals often take longer to render, and
    getting the settings right as you want them, simbiont shader (free plugin for lightwave) itīs tricky to install use if you do not know how though...so if you choose to test you would probably need to shout out here.
    http://www.darksim.com/Repository/tx_Wood/
    hereīs a old render I did some years ago with native lightwave procedurals, modeled in lightwave and rendered with procedurals only for the wood... maybe not adaptable for some wood, and if I had the simbiont shaders at that time..I think it could have looked better, but might work for other stuff, but as mentioned..textures are prefered, thereīs always a scale or repeat issue when using textures on some specific area, so you have to be careful about that.
Name:	Skåp mix 2.jpg
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,925
    That's some pretty good procedural wood prometheus.
    6,957
    Quote Originally Posted by randysolo View Post
    thanks,
    Arroway Textures sound like what you're seeking. Not cheap, can be resource-hungry, but absolutely pro quality, and their species catalog is quite extensive as well. Wood Two has some beautiful species (f.e. look at Ebony & Zebrano in the AJAX catalog).
    France
    498
    You can use "Genetica" either starting from 1 or more photos and/or mixing with the procedurals. The maximum resolution of the Pro version is 6000 X 6000.
    If you prefer a free solution there is a (old but effective) version dedicated to the textures of wood : "Wood Workshop".
    http://www.spiralgraphics.biz/ww_overview.htm
    16,788
    Quote Originally Posted by Areyos Alektor View Post
    Ah...I recall that wood workshop and installed and tested it some years ago, was about to use it for some product shots, but I found my own procedural mix looking more true to how the original locker doors in wood actually looked like.
    need to check back to that again thou or genetica...some day.
    Michael
    Aug 2004
    Ohio, USA
    4,925
    As much as I can appreciate prometheus's procedural wood texture that he was able to muster, there is no substitute for photos of real wood for your furniture or flooring to be used in 3D.
    16,788
    ahh...well today I would probably be able to muster much better with procedural wood only, and different types, but what you say is very much valid anyway, if you can get hold of good high quality textures such as arroway wood, that is
    to be prefered I would say...
    They render faster, and by nature it is almost the real thing.might just be a little harder to apply, but if you know how to do it with uv mapping and editing the textures, thatīs the way.
    Michael
    Super Member Silkrooster's Avatar
    Mar 2004
    Northern New York
    5,254
    I agree, Actually Genetica 4 Studio is capable of images @ 9000x9000
    This jpg was converted in photoshop from a png file for file reduction for the forum. This texture is the basic preset no changes were made. Just to show how large an image can be generated.
    Silkrooster.com - temporarily offline due to updating...
    Spinquad Forum - Closed Sorry...
    lightwave-resources.pdf - - temporarily offline due to updating...
    Aug 2004
    Ohio, USA
    4,925
    Quote Originally Posted by Silkrooster View Post
    Yep - and still doesn't look like wood. I've found some pretty good wood textures on CG Textures http://www.cgtextures.com/
