Page 17 of 19 FirstFirst ... 71516171819 LastLast
Results 241 to 255 of 271
Thread: Lightwave ui+
  1. #241
    Washington DC
    3,627
    Agreed. but you are doing miracles right now.
    I was hoping for some inspiration, not discouragement.
    Keep up the good work.
    -R
    This message does not reflect the opinions of the US Government, CG Networks or CGTALK.com. The opinions expressed on this posting are on my own volition.
  2. #242
    Current version 3.17
    LW_UI+_V3.17
    Fixed:
    - mimimum Surface Editor Height have change in 2015
    - DopeEditor in Instance mode fixed
    - Fixed LW/MD Surface Editors Mixed
    - Modeler Texture editor workflow fixed
    Added:
    - Modeler Tools rethinked. (Height Scalable by Numeric Panel.)
    - Add ShortCuts to Title Bar
    - Modeler Presets Supported
  3. #243
    ..since 4.0 and beyond brent3d's Avatar
    Mar 2005
    Maryland
    345
    Quote Originally Posted by papou View Post
    LW_UI+_V3.17
    Fixed:
    Added:
    Righteous Papou!! Great job all around!
  4. #244
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,451
    Hate to say this again....
    But it still doesn't save the config file correctly.
    Yes.. it now defaults to single screen mode but changing it, and changing Taskbar Visible (which defaults to off) and closing/reloading the app just has those settings revert back.
    Am I the only one this is happening to or what?
    I've tried almost every version released in the last few months and not one of them has saved the settings correctly; is it just me?
    uh wha?
  5. #245
    yep, Hate to hear that again!
    I tought it was fixed... But it may be broken again. Sorry for that. Be sure i'm trying to fixed it from the first time you alert me about.
    First, configuring LW_UI+ need to be done with Lightwave Open.
    (I am preveting the LW_UI+ loop to be run when Lightwave application are closed. So this saving config's code part are ineffective in this case.)
    About NotaskBar State, it's a menu panel refreshing problem. It seems to revert back to default. Your right here. (But the Status is writen and read correctly.)
    CPU Low/Med/High seems strange too. It save only 2 of 3.
    I can't verify DoubleMonitor Right/Left for the moment but it may be the same problem as CPU Usage. Saving 2/3 times only.
    All others values seems to be saved correctly.
    Sorry for that Skonk. You are not alone, but maybe the settings you want to save is not primary preferences.
    Feel free to PM me about this. This can talk in background.
  6. #246
    Yorkshire UK
    1,451
    Heh, right now I see...
    Lightwave has to be open then it saves; that's what I didn't know
    Yes, with lightwave open, exiting the UI app does save the settings.
    uh wha?
  7. #247
    Current version 3.19
    LW_UI+_V3.19
    Fixed:
    - TaskBar Menu now save config in any case.
    - CPU Usage and TaskBar default bugs fixed.
  8. #248
    Current version 3.20
    LW_UI+_V3.20
    Fixed:
    - Somes display bugs
    Added:
    - GraphEditor, DopeEditor & Presets Panel Height Scalable.
    Ok. i'm done!
  9. #249
    Mar 2005
    Maryland
    345
    LW_UI+_V3.20
    Fixed:
    Added:
    Ok. i'm done!
    Well done Papou! A work of art
  10. #250
    Current version 3.21
    LW_UI+_V3.21
    Fixed:
    - LW_UI+ Exit Crashes
    - Presets Panels freeze bugs
  11. #251
    Current version 3.22
    LW_UI+_V3.22
    Fixed:
    - Fixed TaskBar Visible with Modeler in SingleScreen mode
  12. #252
    Hello
    Bitdefender detect this plugin as virus !
    http://seghier.wix.com/designs
    HP 8770w / 3840QM / 32Go / K4000M /Windows 7 Pro 64bits
  13. #253
    Registered User ianr's Avatar
    Oct 2006
    Chiltern Riviera
    1,395
    Thank you many Times Papou,
    Always up there, fine Work....mon brav!
    LW_UI+_V3.22
    Fixed:
  14. #254
    · yep, seghier, Autoit script language is condidered by several antivirus like viral because it's used to survey the user moves. This is the way LW_UI+ works. But it is not surveying anything else Lightwave panels.
    · Thank you ianr!
  15. #255
    Are you continuing to dev. this plugin? I haven't seen any chatter here in sometime.
    Dale L. Campbell Jr.
    Positive Productions Plus!
