Results 1 to 14 of 14
Thread: How can I do beams of light spreading out?
    Jun 2013
    Abq
    60
    I'm trying to simulate light beams or radio waves radiating from a couple different sources (see image). trying to get a more natural look, almost like uniform waves of light and I need them to go from the source and continually move out throughout the animation. Mine are ok, but instead of them just being straight id like the light waves to be curved a little and look more natural.
    The way I did it is i made a transparency image of some faded lines and applied that to the transparency of the surface of the light waves, then to animate them moving out I set an envelope for the position of the image, starting at 0 for frame 0 and moving to 15m for the last frame of the scene
    8,067
    Natural look means using inverse-square law.
    This is proper procedure of making animated light waves:
    Jun 2013
    Abq
    60
    looks a little over my head. Do you know if theres a tutorial that shows how to do this effect? Thanks
    Aug 2010
    Kernow
    2,086
    While there is nothing wrong with the answer Sensei has given, and seems to be actually very correct... you could just use the ripples texture. The spacings a bit off, but it might not bother you.
    8,067
    Good for quick static waves. But how do you want to animate it? Changing texture position doesn't seem to work - it doesn't change wave start angle..
    Aug 2010
    Kernow
    2,086
    It's self animating? Edit :- scrub the time line and it moves.
    Jun 2013
    Abq
    60
    Thanks for all your help guys, this is great!
    8,067
    Ah, right. I had Wave Speed 1.0 and it didn't want to animate. With much much smaller I see effect.
    8,067
    I have made video tutorial of mine approach, which you can see here
    http://forums.newtek.com/showthread....cool-effect%29
    To mine taste 3D Textures Ripples are too close each other.
    Jun 2013
    Abq
    60
    Thanks very much Sensei!
    Jun 2013
    Abq
    60
    I wonder if theres a way to add some volume to these radio waves? Maybe use Sensei's method and use a 1/4 hemisphere instead of a 1/4 disk?
    Jun 2013
    Abq
    60
    Actually, trying same effect with volumetric spotlight instead of 1/4 disk! I'll let you know my results
    Jun 2013
    Abq
    60
    Had to tweak a couple things but works fantastic! Thanks again!!
    Super Member LW_Will's Avatar
    Somewhere, Out there...
    1,188
    Change the scale.
    Will Silver
    Animator
    digital TRiP
    "Frak'em all! I USE LIGHTWAVE!"
