Thread: render current frame to custom path in python
    Mar 2014
    france
    2
    I am trying to do an export script from lightwave in python.
    for that I need to render the current frame at a custom path ( along with a depth map).
    I have found only the command lwsdk.command("RenderFrame") that launch a render but I don't know how to manipulate the GUI to save this image in Python.
    Thanks in advance for any advice or any useful link.
    You can call the commands below like so:
    Code:
    lwsdk.command('SaveRGB(1)'
    lwsdk.command('SaveRGBPrefix(filename)')
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Mar 2014
    france
    2
    sorry, but the commands does not works. ( you have to suppress the parenthesis to make the commands pass the parser)
    And those two commands does not seems to do anything. ( the python answer is 1 but no image is appearing at the path specified)
    I'll double check my syntax but that was copied out of a working script.
    Those two commands just enable options in the Render Globals panel. They don't generate the image.
    www.ernestpchan.com
