Results 1 to 2 of 2
Thread: TC40 playlist isssue
    Once more into the CPU!
    Oct 2006
    Port Orchard, Washington
    439
    So I have a TC40v2 running the latest updated (did one in early March) and yesterday I discovered a glitch with the DDR playlist. I had two SD DV files that were going to play back to back and I did the normal set-up by disabling "Single" and keeping "Autoplay" enabled. When I got to the end of the first video my DDR stopped and all I saw was black... most likely from the first frame of the second video. When I pressed play on the DDR it started up the first video and I had to double click on the second video for it to start all while live.
    Did some testing today and found that I could only get a playlist, 2 or more videos, to work is I had the DDR set to loop. Idea?
    TC Mini SDI 5-1-190425
    -BlackMagic Studio Cam
    -SDI cables
    -Spark SDI
    -LiveText w/SB2
    -YouTube Stream
    _
    SKTV 205
    https://www.youtube.com/user/SKHSVideoProduction
    19,483
    About all I can suggest is to try a new session and see if it still happens.
